Adjustable Fuel Regulator for Sale !!
andysky5
((( God Level 30,000 RPM )))
Adjustable Fuel Pressure Regulator
This adjustable fuel regulator top (aluminium piece as shown in the photo) fits onto the top of your Original fuel regulator to enable u to adjust your fuel pressure to your optimum setting, making it cost effective and very reliable !!
Suitable for : Honda, Proton, Mitsubishi and etc with fuel injection.
Toyota may use the bigger diameter regulator, u can measure to determine your car uses the small or big fuel regulator ( * Not suitable for Myvi, Satria Neo n Gen 2 with campro engine or other cars that does not come with fuel return line !! ** ).
**Made of high quality 6061-T6 aluminium.
Fuel Regulator Selling: rm70 nett
Interested pls. pm or call : 017-3526055 (andy)
For comment on this adjustable type regulator pls click the link below :
http://www.drift.com.my/forum/viewtopic.php?t=19322&postdays=0&postorder=asc&start=30
CLICK HERE to check out more Sales Item !! :burnout:
Photo below shows Wira/Satria 1.6/1.8 OEM fuel regulator (bottom part) fitted with Adjustable fuel regulator (Top part) :
Works just like Nismo type fuel pressure regulator shown below :
Thanks for Viewing:burnout:
may i know whether this fits any engines or not? and... got warranty? thanks
Bro, this fits all engine types. You just have to measure the diameter to determine your OEM fuel regulator fits onto the big or small regulator.
Warranty is given so that it fits onto your OEM fuel regulator without problem. TQ
bump for cheap and reliable fuel pressure regulator !!
One noob question here. How do we know that the pressure is correct when we tune AFR? Do we need some electronic devices to check?
Hello bro, you do need to connect to a fuel pressure meter for tuning purposes. Your mechanic should have this so you can just tune it at your mechanic's place ....or you can but a fuel pressure meter and connect it at the fuel line.
may i know how dis system function?? what the excess while using dis fuel regulator?? can improve the hp or power?? :hmmmm:
