What's a SSBH?
Brakes are usually biased front and less rear. 80-20, 70-30, etc. That's why a lot of people don't bother changing to rear discs and stick with the drum since the drum can be much easily modified to bite harder and more aggressively. Discs are good for the rear if you modify the distribution valve and master cylinder. If you don't, you're just using stock brake pressure on larger calipers which don't really work that well.
