macha,Originally posted by Pyn_57@Mar 3 2005, 13:49
Heelllo .......................
yong....he...happy la you kete dah keluar.....
for you all information for standars block & piston 4g91.... actually not enought power la..... for my experince....la....
1. comperition 4g91 block with 4g92/93 is the high.... let say the block 4g91 we bore and using 4g92/93( same ) piston into the block.....will up a bit power buttt
if using block 4g92/93 block is will be more power......
2. if we combain 4g91 with mivec head....... the mivec system will be on at rpm 5000 rpm the limit around 7500 rpm or more but if using 4g91 block ( standard piston) max limit you can get only 6200rpm ....itu pun kalu ble dpt....so on that time camner lak nak balance the mivec systems....mivec tak nak gile masuk pastu terus cut off.......
3.now i mix 4g91 stock with weber.....3rd gear 140..kmh....top spedd blum lagi...
4g91 actually only more better from 4g15/13 not from 4g92 p......
every depend on your setting/tunning.......( dont always believe with the mechanic....but your self about the logik )
sori my english not so good...........
u sure bout this?? hav u check the engine spec?? or simply tembak?? actly 4g91 and 4g92 share the same strok 77.5 mm, the diff only at the piston dia (4g91 = 78.4 mm, 4g92 = 81mm).. that much difference dont feel power diff then before bore meh.. if u say between 4g93 and 4g91, then its diff story la .. both bore and stroke diff..
on the mivec thing.. if u r using stok ecu, yes.. i agree but 4g91 cut off at 6800 rpm (but still wonder how he activate mivec..).. but i hav a fren who uses mivec head.. activate mivec using RSM.. can set the mivec to open even much more earlier, but this will kill ur FC.. plus remove the rev cut already.. no prob to rev pass 7k rpm.. and u sure mivec standard activate at 5k rpm??
but ur last qoute is thru.. its all depend on setting..
:wavey:
