2012 Lamborghini Aventador LP700-4 6.5 V12 Limited Edition
2012 Lamboghini Aventador LP700-4 6.5 V12 for sale !
0-100 in 2.9s 0-200 in 4.5s only!!!
Excellent condition
Unregistered
Limited edition colour Arab Yellow
Low mileage
Once for life time chances
only for cash PURCHASE only!
make appoinment for viewing@detail
call@whatsapp
DRIVETRAIN
Type of transmission:4WD with Haldex generation IV
Gearbox:7 speed ISR, shifting characteristic depending on drive select mode
Clutch:Dry double plate clutch, Ø 235 mm
Standard:AMT
PERFORMANCE
Top speed:350 km/h (217 mph)
Acceleration 0-100 km/h (0-62 mph):2.9 s
ENGINE
Type:V12, 60°, MPI
Displacement:6,498 cm³ (396.5 cu.in.)
Bore and stroke:Ø 95 mm x 76,4 mm
Valve gear:Variable valve timing electronically controlled
Compression ratio:11.8 (± 0.2) : 1
Maximum power:700 CV (515 kW) @ 8,250 RPM
Maximum torque:690 Nm (507 lbft) @ 5,500 RPM
Emission class:EURO 6 – LEV 2
Emission control system:Catalytic converters with lambda sensors
Cooling system:Water and oil cooling system in the rear with variable air inlets
Engine management system:Lamborghini Iniezione Elettronica (LIE) with Ion current analysis
Lubrification system:Dry sump
TYRES AND WHEELS
ESP:ESP/ ABS with different ESP charecteristics managed by drive select mode
Steering:Steering Gear with 3 different servortonic charcteristics managed by drive select mode
Front tires:Pirelli 255/35 ZR19
Rear tires:Pirelli 335/30 ZR20
Front wheels:19’’ x 9J
Rear wheels:20’’ x 12J
Curb-to-curb turning circle:12.5 m (41.0 ft)
CAPACITIES
Fuel tank capacity:90 l (23.8 gal.)
Engine oil capacity:13 l (3.4 gal.)
Engine coolant capacity:25 l (6.6 gal.)
