2006 CLK AMG- F1 Safety Car
afiqmeister
Engine
Type: V8
Displacement cu in (cc): 383 (6208)
Power bhp (kW) at RPM: 481(354) / 6800
Torque lb-ft (Nm) at RPM: 465(630) / 5200
Redline at RPM: 7200
Brakes & Tires
Brakes F/R: ABS, vented disc/vented disc
Tires F-R: 235/35 R19 - 265/30 R19
Driveline: Rear Wheel Drive
Exterior Dimensions & Weight
Length × Width × Height in: n.a.
Weight lb (kg): 3526 (1600)
Performance
Acceleration 0-60 mph s: n.a.
Top Speed mph (km/h): n.a.
Fuel Economy EPA city/highway mpg (l/100 km): n.a.
In its debut year, the brand-new CLK 63 AMG will also debut as the official Formula 1 safety car for the 2006 season. With its 481 bhp AMG 6.3-liter V8 engine, its modified brakes, suspension, cooling and exhaust system, and an extensive package of lightweight components, the fast-paced coupe is well prepared for its responsible role on the Formula 1 racing circuits. The first outing for the CLK 63 AMG safety car will be at the Bahrain Grand Prix (March 9 to 12, 2006); the standard version will then appear in the second quarter of 2006. Meanwhile, as in previous years, the C 55 AMG estate will be ready for action in all 18 Formula 1 races as the official medical car. Its job is to help as fast as possible at the scene of an emergency.
The CLK 63 AMG Formula 1 safety car will have the task of keeping the Formula 1 racecars safely out of trouble in the event of accidents or bad weather. At a signal from Race Control, the safety car piloted by former DTM driver Bernd Maylander must move into position at the head of the field and lead the cars round the track at the fastest possible speed – since otherwise the high-engine F1 engines will overheat and the tires will lose grip.
The high-speed AMG V8 Coupe is excellently equipped for this job. Its new, eight-cylinder naturally aspirated engine, which was developed entirely by AMG, has a displacement of 6.3 liters and develops maximum power of 481 bhp at 6,800 rpm and maximum torque of 465 lb-ft at 5,200 rpm. The power is managed by an AMG SPEEDSHIFT 7G-TRONIC automatic transmission with steering-wheel shift paddles. For its Formula 1 role, the CLK 63 AMG gets a new throaty-sounding exhaust system which will go down well with motor sport fans both at the track and in front of the TV screens.
The new AMG safety car is well endowed with motor sport technology to help it brave any climate, including a high-performance radiator, two engine oil coolers fitted in the sides of the front apron and an auxiliary, larger transmission oil cooler. The rear axle differential has cooling fins and separate oil cooler.
Racing-derived Suspension and Brake Technology
To optimize handling, further typical racing features of the safety car include an adjustable threaded suspension and 19-inch AMG forged alloy wheels with wide-base tires, size 235/35 at the front and 265/30 at the rear. The safety car has a 70 millimeters wider track at the front and a 60 millimeters wider track at the rear than the standard car, as indicated by the wider wheel arches. The new larger-sized AMG high-performance brake system with excellent braking performance and fade characteristics features 390-millimetre composite discs at the front with six-piston calipers, and 330-millimetre steel brake discs with four-piston calipers at the rear. The brake discs are vented and perforated on all wheels. Since the front brakes take more load than the rear brakes, they are equipped with specially adapted cooling ducts.
Lighter than the Standard Version
In terms of performance, the AMG safety car gets an added edge from being more than 330 lbs lighter than the road version – despite all the additional componentry such as communication equipment, lights, rear axle and brake cooling and the larger wheels and brake system. The Mercedes-AMG engineers made these substantial weight savings by using carbon fiber-reinforced plastic (CFRP), a high-tech material used in Formula 1 and the DTM. The front and rear aprons, the bonnet, the front wings and the doors are all made from this light-weight material. The AMG safety car weighs in at 3526 lbs, and than the standard CLK 63 AMG weighs 3857 lbs (both figures EC kerb weight).
Sophisticated Communication Equipment
The main visual indicators that this is not the standard CLK 63 AMG are the FIA F1 logos and the lights on the roof. The white strobe lights in the headlamps and taillights are always on when the car is in action. They have a neutral function and simply serve to attract attention. To communicate with Race Control, the safety car is equipped with a sophisticated radio system, a TV monitor and TV cameras mounted inside and outside the vehicle. Bernd Maylander's "workplace" is fitted with two bucket seats with 4-point belts, exclusive silver/black leather upholstery, F1 sill panels, a high-grip AMG sports steering wheel and superior-quality carbon trim, all of which emphasize the special character of the new FIA safety car from Mercedes-AMG.
Mercedes-AMG has been supplying the Formula 1 safety car continuously for the past ten years. A V8 AMG E-Class Coupe was used as a medical car as far back as
http://my.is/forums/showthread.php?p=4052843#post4052843
The location of the strobe lights on the roof is a bit off to the back of the car, isn't it? (just comparing with PDRM punye strobelight placement). Maybe the location of the strobe light on the Merc has something to do with Aerodynamic etc..... Nice pics!
BTW, the wheel flarings make the car muscular...
hmm..i still like the SL55 AMG safety car...
The DTM version is hot as well..
For looks, i'll still stick to the SL55 AMG. Its such a beautiful car on and off track. Always see one around USJ area.
However, looking at the all new CLK 63 AMG, its one hell of a hot car too. However, i'm more impressed of the performance stats over the looks. 481 BHP is by no means slow. It'll whack the daylight out of most performance cars.
walau.. this car jadi my personal property so much better rather than being a safety car.. :X-:
like most of u guys, i prefer the SL as well..
tis one juz doesnt look tat good after we've seen SL..
the stats are impressive tho.. and the 4 exhaust pipes looks yummy too~
2nd look at de car.. really look so nice.. *sigh* duno when can own one of these luxury sport cars to myself.. :Not_Impressed:
If this is the same version as the one at the F1 race this year, then this is quite the car. Hugged the corners at the SIC, had amazing acceleration coming outta the corners, and has an engine that sounds like a garang-ish purring cat... or maybe tiger... HEHE. Truly a spectacular piece of automotive ingenuity...
[quote=' xZ "]how much will this car cost in Malaysia?[/quote]
dunno laa..
but i think surely jpj will not approve this car to be on malaysian road coz of the speed..
atrash said:
dunno laa..
lol:_:
u nvr see ferrari, m3, lambo, proshe on malaysia road?
even a ferrari is much more powerful than this 1 ok!:emoticon_U:
