Alright mate. I will give you a ring before i drop by.
If i'm right - V35 offset is 20-35, not sure if 42 may affects steering geometry's scrub radius or problem to torque steer / self centering characteristic. Some advice would be nice.
Weight im not too sure... but as i know is not heavy... because is original Ggames from Japan.. is 100% original... it came with all the original air-valve for each piece of rims.
Bump: Weight im not too sure... but as i know is not heavy... because is original Ggames from Japan.. is 100% original... it came with all the original air-valve for each piece of rims.
Hi Ronin... is the Advan RG original from Japan.. :proud:
If yes, maybe u can drop by my shop in sunway so i take a look first. Just give me a call ya :proud:
Does anyone have an experience using Link G4 management system on your engine, either for street use, street race, or track use? I need to know you experience using this management system on...
While the general consensus has been that the Honda CR-Z is a bit more partial to the green than go side, that hasn’t stopped the tuners from trying to balance out...
