Alright mate. I will give you a ring before i drop by.
If i'm right - V35 offset is 20-35, not sure if 42 may affects steering geometry's scrub radius or problem to torque steer / self centering characteristic. Some advice would be nice.
Weight im not too sure... but as i know is not heavy... because is original Ggames from Japan.. is 100% original... it came with all the original air-valve for each piece of rims.
Bump: Weight im not too sure... but as i know is not heavy... because is original Ggames from Japan.. is 100% original... it came with all the original air-valve for each piece of rims.
Hi Ronin... is the Advan RG original from Japan.. :proud:
If yes, maybe u can drop by my shop in sunway so i take a look first. Just give me a call ya :proud:
i'm using an 03 headlights. and i wana know, the dim light and highlight is yellow. to change the bulb, what size should it be.? i never change b4 so i'm totally clueless. i wana change them to white. it's kinda...
Recently i've read up some articles, found out a good IC SHOULD not only lower down the temp but also to improve flow which shld be the factor if we ever wanna change it.
