1.3/1.5 convert 1.6 CLUTCH kit
BRclutch
Specialist in racing, general clutch, etc.
Ipoh, Perak, Malaysia
Proton 1.3/1.5 convert 1.6 CLUTCH kit at RM350
Most of you guys out there that is driving a Proton 1.3 or 1.5, some of you just want it to be better power and fuel save. solution? some of you already know buying 1set Mitsubishi SuperTouring 2nd hand set from half cut factory, but can you get it easily? Nope. u must pay the price, some more it still not ready to use. ain't it? you need to spend one more day to go and lighten the flywheel buy another set of new clutch just to fit in the 8inch flywheel, ...etc...
We got ready make sets selling at RM350 complete set with lightened Ori flywheel (bearing not included)(bearing charge rm40)
Why pay 350 bugs if half cut shop only cost 180......
So we compare......
1) SuperTouring from half cut shop total weights 14kgs and Ori 1.3/1.5 only 10kgs, so you wil lose top pick-up power and extended your top end speeding power. (How often you might go highway?) So how? BRclutch use the Ori 1.3/1.5 flywheel and lighten it down till total weight 10kgs. By the same time u can maximize ur pick up power and maintain ur top end speeding power.
2)Instead of using mmc's cover which is very heavy pressing for those clutch cable pals, we use either Veloe heavy duty cover or AE86 rear wheel 8" cover which thanks to toyota designs it grips over 100hp n it stil comes very handy....
3)We used semi-racing organic fully Asbestos clutch lining for the new clutch disc it will be more heat lasting around 550c.(year 2010 upgraded to new material til now 2012, heat last 600c) Which is more heat last then OEM 350c heat last Non-asbestos disc.
4)Price wise, if half cut shop offer 180, then the cover might not be able to re-use, then you need to buy a new set around 190+/- again, then you need to lighten your 14kgs total weight to 10 kg. By that u need to spend 50-80 more, let me picture it for you....180+180+80=440...(bearing not included) and make it almost the same price with us, but then it take most of your time to do it (almost a day or two just to send to foundry and buy clutch), and is still not heavy duty cover and fully asbestos lining(so hard to find in normal spare parts shop cos they usually keep regular stock). To get it u need to spend more. But now we have ready made sets and ready for plug n play. And it is sporty performance and more heat last, and it save your time too, you doesn't need to put your lovely car there in the garage for few day just to upgrade your clutch. So u decide....
5)Performance? Is being tested in most proton (since 2006 our first post of this thread til recent years) that it will let you drive longer distance because less clutch slippage means less usage of petrol. Gives you almost 50KM more driving distance in a normal driving mode on a full tank calculation. Means it is fuel save.
6)It will give you more pick-up power due to the rotation weight changed and larger gripping surface.
7)For long distance travel, it won't loose torque power because it still maintain the OEM full sets 10kgs.
*P/S: It will have a minor vibration in the early stage after install, but it will gone after 500km or 2 weeks+/-
Any info of my previous product past few years ago u can visit, My-acoustic.com , go CAR, go GEARBOX, find kianleong clutch(our former name) thx.
We cal it sporty clutch....
contact : 012 5206007 (BRYAN)(wechat, whatsapp ,SMS, viber)
E-mail : [email protected]
installation how much??
where's your location??
took how long to install?
any warranty?
BRclutch use da ori 1.3/1.5 flywheel n lighten it down til total weights 10kgs.
does this mean total = flywheel, clutch cover and clutch plate= 10kgs?
normaly wen someone install this clutch set it happens to b fuel save(cos less clutch slip) slightly increase of pick up, maximum increase grip wen high gear change 2 low gear...( we tested on the heaviers local body-wira sedan 1.5 injection)..... if anything goes wrong..... means.... sum installation problem or engine started out of order n cause it not 2b functioning wel..... note?
the 10kgs maintain is b cos we research from our local car loud usage n daily user, most of them wanna hav pickup n top speed at tha same time. wel...... it cun happen in this engine if it stil stock mode..... so... keep it real..... base on all research we pick da most valueble design, which is wat they having now
im interested but where and how to see the clutch and where is ur shop?? pm me plz
BRclutch Info
sorry, bro the only way u can c the clutch is visit, my shop or ZERO4 racing that is in ipoh or from that pict i post in here..... anyhow i'll post in better pict later on....:X-:
waahhhh,sure spinning wheel on 1st,2nd and 3rd gear,RM300 with installation or not..anyway,free BUMP
BRclutch Info
300 is jes for the product, installation is not included, but i can arange my forman near by u area to do the job n charge u in a fair price....
ps: the 1st, 2nd, 3rd spinning theory is very depent on how powerful ur machine is, as for the clutch is to avoid power lost in the transmision n longer heat lasting...., pls dun b misunderstand.....:_:
new info, some of my customer that oredy install BRclutch wil attemp the kg.gajar drag racing........
good news, not bump one...... jes today 7th may 2006, two of my customer get champion in a drag competetion in perak, kg.gajar. ones PANJANG from allifnos motorsport get champion in1.6 catorgory in his 1.6 zc kaw2 engine. another is WONG KEN CHONG from zero4racing winning the 1.8 catorgory champion n open catorgory 1st runner up, by his special blend 4G93NA... they both using BRclutch, thanks them here.... the feedback is good....happy....
Hai Bro,
If I wanna buy from u, how is it? u sent by post or u'll come down here after bulk order from everybody.
Can u give ur shop address in case I go to Ipoh.
Thank bro.
BRclutch INfo
aedes666 said:
Hai Bro,
Thank bro.
90, Jalan leong boon swee, 31650 ipoh perak....:Not_Impressed:
BRclutch Info
hellspermz said:
bro if i want it how?
im in kl....
got two ways, my bro wil come to k.l. nex monday, once u comfirm i'll ask he to meet u n pass to u on spot u pay lah... or... u TT the amount to our bank account before 5pm everday so that we can sent the product on spot, n u wil recieve by the nex day, cal me or pm me for more detail...0125206007 bryan..:_:
BRclutch Info
kayang said:
4g91 can use?thanks
Nope... urs is DOCH, is a deferent design racing clutch, pls check, 350 BRclutch.... cos urs same with 92, 93NA, Mivec.....:_:
