Car Clubs
Car Club Categories
RE Club Malaysia
Xchange ...
<blockquote data-quote="jasonlel" data-source="post: 1041950" data-attributes="member: 419"><p>First of all are you using a OEM clutch now? If yes, then you can use back the clutch cover/pressure plate and get a new disc. You want to get the whole new set also can. Whole new set would include clutch cover/pressure plate, clutch disc and throw out bearing. This set cost about RM1.5k excluding installation</p><p></p><p>Secondly is best if you can identify if you are having a whole set of exedy clutch. Exedy clutch plate and disc.</p><p></p><p>Hmmm I dont think you can rojak exedy and oem clutch. Any guru can verify this?</p></blockquote><p></p>
[QUOTE="jasonlel, post: 1041950, member: 419"] First of all are you using a OEM clutch now? If yes, then you can use back the clutch cover/pressure plate and get a new disc. You want to get the whole new set also can. Whole new set would include clutch cover/pressure plate, clutch disc and throw out bearing. This set cost about RM1.5k excluding installation Secondly is best if you can identify if you are having a whole set of exedy clutch. Exedy clutch plate and disc. Hmmm I dont think you can rojak exedy and oem clutch. Any guru can verify this? [/QUOTE]
R35 Used Titanium Exhaust
DIY: Mercedes CLK 200 - Exterior Correction and Interior Protection
Hello all, just sharing my humble work. This Mercedes CLK200 has been Meguiarized, Duraglossed and...
180kmh Speed / fuel cut
Hi bros, I have a small dilemma with my car. Earlier on, i thought that I could live with the 180kmh speed / fuel cut, but obviously it's not the case anymore... Has anyone here ever successfully bypassed / removed /...
skyline for bridal car
Hi,any sifu at here need some help.... did yours use skyline as bridal car before?Have some picture? Many Thanks.....:regular_smile:
Car Clubs
Car Club Categories
RE Club Malaysia
Xchange ...
