Main Forums
Interests
ICE
wuts best for kelisa???
<blockquote data-quote="Kippo" data-source="post: 393272" data-attributes="member: 10096"><p>For me the bigger the better. Get the 12" subs.</p><p>Since you are a beginner, use sealed box. If you have some ppl who can build good ported box, go for the ported box.</p><p></p><p>Reason i recommend you to use sealed box is because the % of vol. error tolerance which is in the range of 10% ~ 20%. So good for beginner to start with. Ported box is not really forgiving for error.</p><p></p><p>but one thing with sealed box, you need good amp due to lower efficiency compared with ported box.</p><p></p><p></p><p>bert,</p><p>i would assume the backseat as sedan car rear seat which blocks the air from the boot. Estimated of 3dB loss for sub installed in boot.</p></blockquote><p></p>
[QUOTE="Kippo, post: 393272, member: 10096"] For me the bigger the better. Get the 12" subs. Since you are a beginner, use sealed box. If you have some ppl who can build good ported box, go for the ported box. Reason i recommend you to use sealed box is because the % of vol. error tolerance which is in the range of 10% ~ 20%. So good for beginner to start with. Ported box is not really forgiving for error. but one thing with sealed box, you need good amp due to lower efficiency compared with ported box. bert, i would assume the backseat as sedan car rear seat which blocks the air from the boot. Estimated of 3dB loss for sub installed in boot. [/QUOTE]
david tao
Need step by step picture guide to replace Myvi2005 from front absorber mounting
Need step by step picture guide to replace Myvi2005 from front absorber mounting. Anyone can share ?
1Sahar 3S-GTE running rich mixture?!
The defect and its symptom are:
1. Idle with black smoke.
2. Engine jerk when idling.
3. spark plug goes black and after replacement its ok for a while but later will be like running on 3 cyl.
4. Changed plug ...
Special Visitor and Track Timing at 2007 F1 Team Testing Sepang Circuit
SPECIAL VISITOR AT F1 TEAM TESTING IN SEPANG.
The first ever Official...
Main Forums
Interests
ICE
