{WTS} Nanoblock (remove ur car's bad odour)
Checkers
Upgrades / Improvements
- better adhesives to hold the nanoblok pad on the dashboard ver
- higher grade material and thickness
- improved nano formulation
http://img87.imageshack.us/img87/7536/nano1kb0.jpg
http://img87.imageshack.us/img87/9827/nano2gr5.jpg
http://img228.imageshack.us/img228/3931/nano3fb3.jpg
NANOBLOK PAD for only RM0.05/day for 2 years
NanoBlok Pad physically traps & decomposes bacteria and bad odours (e.g. cigarette). It does not contain masking scents and is comparable to 1kg of charcoal in effectiveness. Simply attach the self-adhering NanoBlok Pad onto a surface sunlight can reach. The dashboard or rear board of your vehicle would be ideal to absorb bad odours.
• Deodorize passenger cabin.
• Anti bacteria protection.
• Sirim tested, same technology used by Toshiba & LG.
• Comes with self adhesive backing for instant application.
How it works:
By combining Nanotechnology and photo catalytic technology, our state of the art Nanoblok pad can deliver a powerful reaction to kill/decompose bacteria, viruses and other biological pollutants and bad odour. With the existence of UV lights or natural lights, the decomposition process will be expedited faster and harmful substances that stick on the surface area are completely broken down into carbon dioxide and other harmless compounds.
How it helps:
Nanoblok helps to rid the common smells that can be irritating to car users:
- damn / wet carpet smells
- cigarette smells ( works best for driver's who smoke in the car AND have thier passengers complain of the bad smoke smells )
- durian smell
- musky smells from your air conditioning
- animal poop ( to those unfortunate enough to step on dog poo )
- vomit smell
- fermented milk
- dead fish
- pet smells
Cost Savings:
Save your money! You no longer need to spend money on perfumes. On average a perfume has to be refilled monthly and this leads to spending more than a hundred ringgit a year. Nanoblok is cost effective as it has a minimum life span of 2 years and is practically maintenance free. An average perfume refill lasts about a month , over 2 years is 24 months , which means u spend approx. RM240 every 2 years
Nanoblok lasts for A MINIMUM 24 months , which means u only spend RM39.90 instead of RM240.00
Coverage area:
A single pad of Nanoblok works well for most standard vehicles. Placing Nanoblok on the front and rear parcel board for larger vehicles would be an added advantage.
The science
Nanoblok is another product for car that uses nanotechnology in preparing the metal oxide + activated carbon particles, which are then embedded into resins to make the fibre.
Basically, the activated carbon nanoparticles trap the ordor (gaseous) molecules into the particles' porous structure, and the metal oxide decomposes the molecules using the energy from the UV (Sunlight).
Nanoparticles of metal oxide are also used in skin care product - Sun Block. It absorbs the UV energy and transforms it into free electrons, which then taken by the emulsion.
In Nanoblok, the electrons are targetted to the odor molecules. The end result is decomposition of the molecules.
FREQUENTLY ASKED QUESTIONS (FAQ)
• I have a new car! Can I use Nanoblok?
Definitely! Nanoblok is suitable for both new and old cars. Nanoblok will help remove harmful toxins / gas emitted from plastic or vinyl from your brand new car.
• I like to have perfume is my car but I still want to use Nanoblok too. Will there be any perfume smell left?
Yes, you can still use perfumes in your car if that is your preference, Under optimum conditions, Nanoblok will absorb most of your perfume smells but deactivates during the night which allows your perfume to work and you will actually have a balanced light perfume smell in the morning as opposed to a choking smell caused from leaving your car unattended for some time.
• My Nanoblok does not seem to work?
First time users always forget that Nanoblok uses photo catalytic technology to activate meaning it needs UV or natural light to work. Simply leave your car in the sun and let Nanoblok do the hard work of clearing foul smells from your car.
• How do I clean my Nanoblok?
Nanoblok is practically maintenance free but if you want to clean it simply vacuum off the dust if any or use a slightly damp cloth to clean the surface area.
• How long can Nanoblok last?
Anything left under the sun may discolour after a certain time. We recommend changing Nanoblok every 2 years simply for aesthetic reasons. Without disturbing the surface area Nanoblok has the potential to last much longer.
• Will the glue stain my dashboard?
No! The adhesive used does not leave a stain on your dashboard. A test on a Nanoblok pad stuck on for more than 6 months came off easily without leaving an adhesive stains whatsoever.
Call or sms amir at 012-3136229 Price Rm39.90/pc
For purchase more than ONE, u can get MORE discounts
for satria, use 1pc enough?ur location?
Yeah, 1 pc enough for front dashboard..unless u want to put it on the back.also can.depends on driver/user.
My location is Cheras/Bangi/Kajang.sms/call me for more details
Update...
Item really works.
Thanks to all
Just COD at Tesco SAujana Impian..
Bump..
ya...limited stock now.
pls do sms me to deal
012-3136229 (amir)
