Ever experience any car breakdown due to the battery? Well, with E-power, you do not have to worry anymore, its only a few easy steps away to jump start your car.
Specifications:
patent product 5 in 1.Multi-functional
Mini smallest lightest
Portable
Lithium battery
Patented design
12V car battery jump starter - EPower Elite
Product parameters:
Weight: 420g
Output:
5V/2A; --- Mobile phone, Tablet PC, PSP, MP3/MP4…
12V/2A; --- Vehicle cooler..
19V/3.5A; --- Laptop PC (Does not support Macbook)
Jump start;--- 12V vehicle
LED light --- (light, burst flashing, SOS)
Input:
12V/1A
Starting Current: 200A
Peak Current: 400A
Instructions for use:
1, Select the appropriate voltage and connector for the electronic device to charge / power supply
2, Press the switch to start charging when your device connected with EPOWER; If you unplug the cable, auto-sleep will start in one minute.
3, Five lights will flash circularly during the charging by EPOWER and all lights will keep bright when your device is full-charged
4, During the charging for your device, LED lights indicate the balance power of built-in battery of EPOWER. Four lights indicate 80% balance, three lights indicate 60% balance, two lights indicate 40% balance and one light indicates 20% balance. The built-in battery is empty whenall LED lights start to flash
5, Press the switch three seconds to start If you want to use LED for illumination and select the status ( light, burst flashing, SOS, close) by pressing the switch to transform.
6, Store the product in a cool and dry place and away direct sunlight.
Special note:
To start 12V vehicle, please assure that there are at least three LED lights of EPOWERare bright, then connect the Red battery clamp to the battery Positive (+) and Black clamp to the battery Negative (-) and insert the plug into the EPOWER, finally turn the ignition switch to the START position. Once the vehicle is started, please disconnect the plug and remove the battery clamps within 30s.
Product Highlights:
The smallest and lightest jump starter with patented technology in the current market.
Use high power polymer cells, fast charging and low self-discharge, cycles can reach 1000 times.
Support 12V vehicle for emergency start, portable illumination and various mobile phone, PSP, MP3/MP4 Pocket PC PDA, notebook as well as other products charge / power supply.
This awesome product is only going at the price of RM250, cheapest you can get. 100% Original with 1 year warranty.
For more information on the product, please contact us @ 018-2651688.
Specifications:
Portable
Lithium battery
Patented design
Product parameters:
Weight: 420g
Output:
Input:
12V/1A
Peak Current: 400A
Special note:
Product Highlights:
