Car Brands
Car Manufacturers
Daihatsu
WTB: GTti Engine Kosong
<blockquote data-quote="blueteg" data-source="post: 1484997" data-attributes="member: 4707"><p><strong>Engine is in!</strong></p><p></p><p>Hi guys.</p><p></p><p>Just thought you guys should know I finally got the new engine. My mechanic found it. Cost a bomb, because he engaged the help of his runner.</p><p></p><p>Anyway, I don't really care about the cost anymore, since I'm just relieved the car is running well now. Previously it used to surge, choke and struggle a little. Now it's running standard boost, and everything seems in good order, except the lambda sensor. Still haven't found the right lambda/oxygen sensor.</p><p></p><p>Just writing to thank all of your for helpful suggestions and tips.</p><p></p><p>Cheers!</p></blockquote><p></p>
[QUOTE="blueteg, post: 1484997, member: 4707"] [b]Engine is in![/b] Hi guys. Just thought you guys should know I finally got the new engine. My mechanic found it. Cost a bomb, because he engaged the help of his runner. Anyway, I don't really care about the cost anymore, since I'm just relieved the car is running well now. Previously it used to surge, choke and struggle a little. Now it's running standard boost, and everything seems in good order, except the lambda sensor. Still haven't found the right lambda/oxygen sensor. Just writing to thank all of your for helpful suggestions and tips. Cheers! [/QUOTE]
jeff6126
Honda Jazz FLRS side skirt
jeff6126
yellowcaliper /caliperspray
jeff6126
Te37 Track Edition 2 FK8 FL8 Civic Type R Rim Wheel...
Revozport R35 GT Wing Spoiler and Trunk
original rare Work Emotion 11R 18x8.5jj offset +47...
david tao
Spoon FK8 FL5 19 inch rim wheel Type R
Litchfield GTR R35 Road Suspension Kit Absorber
original rare Yokohama ADVAN Racing RG3 18x8.5jj...
david tao
~accident repair ~touch up paint
jeff6126
confused
i confused wat de diffrence of apexi afc neo and e manage blue
i'm planning to put management on my wira already convert evo 1 engine
some mechanic say u just put apexi neo enough la...
need ur opinion to all sifu...
Throttle BODY
:proud:I am looking to Upgrade my Throttle Body for E3(CE9A) any one good any ideal on which and how?
I see many 63mm for rebuild or 70~75mm for new one...
any advise
wheels u might want?
http://www.zerotohundred.com/newforums/chassis-and-wheels/206777-16-5-stud-enkei-racing-wheels.html
david tao
Car Brands
Car Manufacturers
Daihatsu
