Main Forums
Interests
Do-It-Yourself Garage
WTA Disable Alarm System
<blockquote data-quote="ylkien" data-source="post: 4013384" data-attributes="member: 13445"><p>I think his problem is as such. Please correct me if I am wrong.</p><p></p><p>1) Central locking not working properly.</p><p>- Both doors on the left can't lock/unlock properly</p><p>- This has nothing to do with the main alarm system, cause the central locking system is still working. It is most likely due to faulty motor.</p><p></p><p>2) Immobiliser not functioning, thus unable to start the car.</p><p>- Most likely the main alarm unit isn't working properly.</p><p>- Solve this by tracing the ignition wire to alarm (usually behind the dashboard). It should be connected directly to the main alarm unit or through a relay.</p></blockquote><p></p>
[QUOTE="ylkien, post: 4013384, member: 13445"] I think his problem is as such. Please correct me if I am wrong. 1) Central locking not working properly. - Both doors on the left can't lock/unlock properly - This has nothing to do with the main alarm system, cause the central locking system is still working. It is most likely due to faulty motor. 2) Immobiliser not functioning, thus unable to start the car. - Most likely the main alarm unit isn't working properly. - Solve this by tracing the ignition wire to alarm (usually behind the dashboard). It should be connected directly to the main alarm unit or through a relay. [/QUOTE]
david tao
A few Questions from ZTH members.
in 3 years time, what would an unregistered fairlady be priced at?
am only asking about roughly.
now its about 160k to 190k 03' version.
do you think they'll still have unreg. 350s ?
DIY Install Ultra Racing 3-Point Fender Bar
--deleted--
*wrong nick :p
Greedy Type-R BOV
Anyone here used or using this BOV ?
how does it sound like ?
suitable for low boost and high boost ?
thanks mate.
SDF : u were using it rite ?
Main Forums
Interests
