WORKS Engineering Engine Oil Cooler Kit
powerautohauz
((( God Level 30,000 RPM )))
WORKS EBGINEERING OIL COOLER KIT
Oil Cooler Kit help prolong the life of your oil and in turn your internal engine components. Hard driving causes higher engine temperatures. Factory oil coolers are normally small water-cooled devices sandwiched between the oil filter and engine block. These tax the cooling system even under normal driving conditions.
Because the latest generation of engines are smaller, run at higher RPMs and produce more heat, maintaining the correct oil temperature is imperative. In addition, most engines have less oil capacity, putting more of a strain on the oil and engine components.
WORKS oil coolers are an excellent addition and are especially effective in harsh driving environments, With our inner-fin core design, we are able to increase oil capacity, decrease oil temperatures, and extend engine and oil life. The efficient core and durable lines ensure good flow and a leak free installation. Included in the kit is a mounting plate which is also a convenient place for oil pressure and oil temperature sensors installation.
Works oil cooler kit consists of high quality, billet aluminium components and fittings – comparably priced kits are typically cast.
Bakuso Racing Sdn. Bhd.
No.21, Jln PJS 11/24,
Bdr Sunway.
47500 Subang Jaya.
Land Mark:
Desmond 017-396 8567
Email us : [email protected]
