Main Forums
Interests
Do-It-Yourself Garage
Woofer Light
<blockquote data-quote="levin818" data-source="post: 37612" data-attributes="member: 849"><p>yup its using condensor mic (for handsfree type) to pick up the bass signal, amplified and trigger the LED/bulbs. Perhaps can tap the signal directly from the woofer but need to step down the voltage.</p><p>Kit is easy and less hessel. Should be able to get from Jln Pasar. Sorry no diagram on hand at the moment...</p></blockquote><p></p>
[QUOTE="levin818, post: 37612, member: 849"] yup its using condensor mic (for handsfree type) to pick up the bass signal, amplified and trigger the LED/bulbs. Perhaps can tap the signal directly from the woofer but need to step down the voltage. Kit is easy and less hessel. Should be able to get from Jln Pasar. Sorry no diagram on hand at the moment... [/QUOTE]
R35 Used Titanium Exhaust
Motormyth's magical photos of the Time To Attack Finale 2010
From http://www.motormyth.com: It was a thrilling end to the now infamous Time to Attack: Sepang series of time attack...
DOOR GLASS (GENUINE) for ECR34/BNR34 for sale
got a pair of door glass for ECR34/BNR34 for sale. both in good condition.
call me if u need it 012-2988 288. RM1600/pieces
Can anyone modify the Mitsubishi Digital Aircon Panel Outside Temp Sensor
hey sifus... I was wondering if anyone knew how to modify the Mitsubishi Digital Aircon Panel. It has a button on the top left that show the Outside Temperature. I was wondering if I can tap that sensor or connect...
Main Forums
Interests
Woofer Light
