Main Forums
Car Talk
Car Modification
wira 1.5 se standard..
<blockquote data-quote="loose_end" data-source="post: 3396602" data-attributes="member: 78628"><p>Once you play NA style , then you will gain a little HP..After that , you will feel bored about it..Some sort of like not enough power..So , you decide to change engine since 4G15 could not reach your power satisfication..therefore , its better for you to use the shortcut directly by changing the engine..If not , you would have to follow the path , step by step and remember..your $$ have been invest in your 4G15..</p><p></p><p>Ask yourself - What is your budget ? How much power do you need and for what purpose ? Would the wira 4G15 be able to cater for your future needs or should you be looking for another engine ?</p><p></p><p>Just my opinion ya</p></blockquote><p></p>
[QUOTE="loose_end, post: 3396602, member: 78628"] Once you play NA style , then you will gain a little HP..After that , you will feel bored about it..Some sort of like not enough power..So , you decide to change engine since 4G15 could not reach your power satisfication..therefore , its better for you to use the shortcut directly by changing the engine..If not , you would have to follow the path , step by step and remember..your $$ have been invest in your 4G15.. Ask yourself - What is your budget ? How much power do you need and for what purpose ? Would the wira 4G15 be able to cater for your future needs or should you be looking for another engine ? Just my opinion ya [/QUOTE]
david tao
intercooler different
Found quite some ARC intercooler sell at few hundred RM in the market. What;s the different between these 'ARC' and ori ARC that cost a lot more expensive?
Some SA22C parts for sale
Here are some Sa22c parts that are for sale, helping a friend post this.
-Rear lights
-Meter panel
-Number plate lights
For more details and enquiries on pricing, please call Joe at 016 2323994...
How To Install Sound System
Dear all,
Anyone can share knowledge on how to install car sound system??
I have CD player, Pre-amp, 2-channel Power Am, Component speakers and coaxial speakers... anyone, thanks. BTW, send to kedai, mahal...
Main Forums
Car Talk
Car Modification
