Windscreen water spray not working
simplythebest
1,500 RPM
Selangor
The windscreen water spray on the bonet .. the right one is working but the left one having difficulties spraying the water out. What are the things should I check? :unsure:
Originally posted by NiCkY7@Sep 2 2004, 05:29 PM
check the tube which deliver the water...
already check, its connected .. but not sure whether its fixed properly or left out anything or not. :unsure:
Ermm..try getting a sharp needle and shove it right into the wiper water nozzle and see whether it works or not.
Sorry for hijacking this thread, but does anyone know where to buy replacement nozzles? The ones I managed to find are those 'ah beng' type (colour LEDs)... :(
the blocked wiper washer can easily be solved by using n pin or needdle..
poke into the hole.. then try.. if kenot try poking wit some spinning... :lol:
u can also adjust the angle... by aiming the hole while poking.... :lol:
happy trying / happy poking!! :lol: :lol:
cheers!!!
Originally posted by hamsap@Sep 2 2004, 06:34 PM
acbc,
Can always try the normal spare parts shop and see.
Do u know of such shops around Damansara area?
acbc,
i got one friend open shop there uptown...10++ years oledi...u can always find a white scooby park infront of the shop...owner's ride.
T.Y motor parts supply
71,Jln SS21/60,
Damansara Utama
Tel : 77294816
Ok, i use a needle poke both tiny holes .. then I try it works but the water simply pancut .. now even worst no water at all when I try. Whats nozzles? the water spray on bonet? (i dunno what is that called). Guess I need to change a new one.
no need change lar..
u can adjust the angle using de needle.. while it is still poking inside de hole. :lol:
Yeap dude...
That's nozzle...
Like khguan said, just adjust with needle of where u want it to shoot... :)
poke deep as you can..
make sure the tube are install tightly and not broken tube
Originally posted by bryan90s@Sep 7 2004, 05:23 PM
acbc,
71,Jln SS21/60,
Damansara Utama
Tel : 77294816
Thanks... I'll go down tomorrow morning...
Err, who do I look for? :P
acbc,
got one more in seapark I think. Its called PH autolink or something..next to caltex or shell or something..heheh Friday mah, kennot think properly..
