Car Brands
Car Manufacturers
Honda
Which Setup Will u go for??
<blockquote data-quote="shiroitenshi" data-source="post: 2905080" data-attributes="member: 27518"><p>nah.. that's near impossible if you want to retain air-cond and powersteering.</p><p></p><p>I'm estimating around 180-190atw, at 9K rpm</p><p></p><p>10,000 rpm B16A, possible, I think.</p><p></p><p>The main issue is trying to get the peak torque to be in the 7-7.5K range to ensure you hit that kind of hp at peak rpm of 8-9. if 10Krpm engine, peak should be around 7800-8000 rpm, that's easier said than done, there's always some sort of flow restriction that keeps the peak at the 6-7K range. I think porting is the next logical step, but I'm not so sure about recommending any sort of porting work.</p><p></p><p>Those C&C ported heads are nice, but EXPENSIVE.... very much so.</p></blockquote><p></p>
[QUOTE="shiroitenshi, post: 2905080, member: 27518"] nah.. that's near impossible if you want to retain air-cond and powersteering. I'm estimating around 180-190atw, at 9K rpm 10,000 rpm B16A, possible, I think. The main issue is trying to get the peak torque to be in the 7-7.5K range to ensure you hit that kind of hp at peak rpm of 8-9. if 10Krpm engine, peak should be around 7800-8000 rpm, that's easier said than done, there's always some sort of flow restriction that keeps the peak at the 6-7K range. I think porting is the next logical step, but I'm not so sure about recommending any sort of porting work. Those C&C ported heads are nice, but EXPENSIVE.... very much so. [/QUOTE]
R35 Used Titanium Exhaust
Reservoir tank problem ?
Helo ,
I have recently noticed that the water level of my car reservoir tank is dropping whenever I drive .
So I top it up daily , usually will be less than a half of the tank .
I tried figuring out the problem and...
AR 80 (from sr20)
sorry if i post it at the wrong section ler~
just wanna know if anyone used AR 80 (from sr20) before?
the size compare to td05?
the responds? compare to td05? (or other similar turbine)
the review from some of the...
Altezza for sale....
I am letting go my ride. Details as follow:
Basics:
- Year 2001; Registered 2006
- Beams RS200 3S-GE, 5 A/T triptonic, silver colour, nice number
- L-edition (GPS navigational, 4 airbags, beige interior, original...
Car Brands
Car Manufacturers
Honda
