Car Clubs
Car Club Categories
The Cefiro Club Malaysia
Which headlights to go for?
<blockquote data-quote="defcon1" data-source="post: 2259286" data-attributes="member: 30064"><p>Erm...did I hear someone use my name in vain?... <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite1425" alt=":smile:" title="Smile :smile:" loading="lazy" data-shortname=":smile:" /></p><p></p><p>Actually, I have no idea how many wires go to my signal lamp. However, in the past, whenever I have been faced with this situation, and cannot find a fitting plug, I simply change both sides of the connector - both the male and female. A trip to the local scrap yard will yield miles of discarded tangles of wire harnesses with a variety of connectors attached. You simply need to find an appropriate one.</p><p></p><p>For lights, if it is 2 wire (common), then that's simple. If it is 3 wired, then it is likely that it is a looped circuit...i.e. the positive probably connects to some other light or is intended to loop to some other signal light that may not be present in your car. Trace the original wiring through that connector and make sure that the wires match up...and it will work without problems...and with a brand new connector that will not leak... <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite1425" alt=":smile:" title="Smile :smile:" loading="lazy" data-shortname=":smile:" /></p></blockquote><p></p>
[QUOTE="defcon1, post: 2259286, member: 30064"] Erm...did I hear someone use my name in vain?... :smile: Actually, I have no idea how many wires go to my signal lamp. However, in the past, whenever I have been faced with this situation, and cannot find a fitting plug, I simply change both sides of the connector - both the male and female. A trip to the local scrap yard will yield miles of discarded tangles of wire harnesses with a variety of connectors attached. You simply need to find an appropriate one. For lights, if it is 2 wire (common), then that's simple. If it is 3 wired, then it is likely that it is a looped circuit...i.e. the positive probably connects to some other light or is intended to loop to some other signal light that may not be present in your car. Trace the original wiring through that connector and make sure that the wires match up...and it will work without problems...and with a brand new connector that will not leak... :smile: [/QUOTE]
david tao
federal 595 evo vs hankook v12 vs michelin pp2
which one is better in term of performance and cost?
Federal 595 evo
or
Hankook v12
or
Michelin pp2
Any comments?
Driving-Driving Find Food (29/08/2009)
I hope the owner of the cars doesn't mind me putting their rides up in my blog. But I thought of sharing some of the pics from a great evening out in town.
But sorry....u have to go to this link. Very the malas to...
Cheap GTR R35 For Sale :P
Gotcha! hihihihihi
:wavey:
24/04/08
http://www.gtrblog.com/index.php/2008/04/24/nissan-gt-r-1-24-scale-models-coming-soo?blog=4 01:07:04 pm, by
Kris
Car Clubs
Car Club Categories
