Car Brands
Car Manufacturers
Toyota
Which better to mod
<blockquote data-quote="rollakid" data-source="post: 260509" data-attributes="member: 6588"><p>4agze do not need to change the internal, since you only change the way they pump in air. I'm told that the gze internal is perfectly safe for boosting under 300hp.</p><p></p><p>the standard 9.4:1 4ag from ae86, with malaysian's RON97 petrol, should be able to run a low boost, probably only a few psi. But thats theory, i dunno for sure but i sure won't recomend it. The piston is not forged and you will risk blowing your engine. and if you are to run 3psi to 4psi with it you better tune it in NA..</p><p></p><p>and i don't think 4agze deal with vvt.. they are only found on 20v</p></blockquote><p></p>
[QUOTE="rollakid, post: 260509, member: 6588"] 4agze do not need to change the internal, since you only change the way they pump in air. I'm told that the gze internal is perfectly safe for boosting under 300hp. the standard 9.4:1 4ag from ae86, with malaysian's RON97 petrol, should be able to run a low boost, probably only a few psi. But thats theory, i dunno for sure but i sure won't recomend it. The piston is not forged and you will risk blowing your engine. and if you are to run 3psi to 4psi with it you better tune it in NA.. and i don't think 4agze deal with vvt.. they are only found on 20v [/QUOTE]
R35 Used Titanium Exhaust
Taking Airtrek to the next level
Magisto Video | Mitsubishi Airtrek with TRON Flexible Daylight + Signal Function
or
Magisto Video |...
VIDEO: Mercedes-Benz CLK C63 AMG Black Series - 507bhp of Evil
Mercedes-Benz has just loosed their version of 'vicious' with their CLK C63 AMG Black Series that...
Does old engine mounting causes steering vibrations at high speeds ?
Recently I have change my driveshaft and also new tyres, checked balancing, alignment n camber.
But why does my steering vibrates at 120kmh onwards ? Could it be the old engine mounting I havent changed?
btw, I am...
Car Brands
Car Manufacturers
Toyota
Which better to mod
