Where to get new parts?
aspec_fc
Really; I thought is pretty damn hard to get new parts around in Malaysia. Where do you guys get parts like sway bars, suspensions, polyurethane bushings, and all those good stuff for FCs?
thanks in advance!
i think we must keep this blog active for re. you know certain things i experienced the local parts centre don even know from their record and after asking around they still could not find.
so far my experience is to get gear box rear oil seal, fuel filter, gear stick bottom slot etc.
Most of the new parts or even used parts are no longer easily or readily available locally. That is why most of us get parts from japan or other foreign countries.
i did not know this turbo steel gasket could be sold at 270 for new!! i have collected almost all the turbo steel gasket..
hmm.. who has the discontinued MS carbon e-brake lever? If its up for sale, please pm me. I will give you a good price.
i suggest we list down the new parts from where and what brand we have bought before so the newbie could know where to source them..
i start with
1)fuel filter, buy from any shop , use hyundai one
2)oil filter, the same
3) clutch disc, oem, i used exedy (buy from mechanic) before, give burning smell. then used act 6 pug ceramic(buy from k l act dealer), still oem clutch kit. very happy, no burnt smell even if you drift.. others pls share.
Hi,
I'm a newbie to this rotary land. Currently rebuilding my stock fc3s engine. I need help from all the sifu's ans guru's here to advice me on:
1. what is the best clutch set for normal driving.??
2. how much is the cost.?
3. clutch bearing.??
Thanks.
IMHO, best clutch for daily driven/normal driving if your car is stock setup would be the stock clutch. I'm not sure about the cost for now. I can ask Ah Choy when I see him tomorrow. Which clutch bearing are you talking about? Throwout bearing or the pilot bearing? Both are inexpensive.
Just for your reference. I'm running MS lightened flywheel, 3" exhaust system from downpipe to muffler, stock turbine, stock intercooler, HKS air filter and that's pretty much so for my power upgrade; i'm running stock clutch which is fabulous. I have my car as daily driven.
aspec_fc - I would be my honour if u can asked Ah Choy :
1. clutch set (err.. does it come with clutch-plate.?)
2. stock water pump (new)
price for part only. without labor..
thanks in advance
