Main Forums
Interests
ICE
When to install power capacitor ?
<blockquote data-quote="kyheng" data-source="post: 966160" data-attributes="member: 13624"><p>Well, I've check the forum, the first 3 pictures it never state how many watt of system is using. But i assume that the system is more than 1000watt. Without a cap the car system volt will drop to a very minimum at 9.8v, with a 1 farad the minimum is 11.6v, with a 50 farad the battery never load at all. These minimum peak is when the music bass is the highest on that time, the same time the alternator also cannot supply back enough power. If the battery starts to get old, the bass when hit at these time, the bass will not be deep like new battery can perform. </p><p>On the 4th pic, the 50farad can perform best compare to the other 2 when on 1ohm load which is some subwoofer load at 1ohm. From here we can know that with a 50 farad cap the sub can perform best on 1ohm, not like the other. So sometimes the installer say when install a cap your woofer will have a deeper bass is true on some sence, but for true statement is with a cap your bass will not much affeted by the battery power as the cap is doing its job...</p></blockquote><p></p>
[QUOTE="kyheng, post: 966160, member: 13624"] Well, I've check the forum, the first 3 pictures it never state how many watt of system is using. But i assume that the system is more than 1000watt. Without a cap the car system volt will drop to a very minimum at 9.8v, with a 1 farad the minimum is 11.6v, with a 50 farad the battery never load at all. These minimum peak is when the music bass is the highest on that time, the same time the alternator also cannot supply back enough power. If the battery starts to get old, the bass when hit at these time, the bass will not be deep like new battery can perform. On the 4th pic, the 50farad can perform best compare to the other 2 when on 1ohm load which is some subwoofer load at 1ohm. From here we can know that with a 50 farad cap the sub can perform best on 1ohm, not like the other. So sometimes the installer say when install a cap your woofer will have a deeper bass is true on some sence, but for true statement is with a cap your bass will not much affeted by the battery power as the cap is doing its job... [/QUOTE]
A Sad Day: First GTR Crash
We don’t even officially have it here yet and people in Hong Kong are already wrecking their GTR’s. There is no...
Recommendations on upgrading of ECU of ER34
Dear skyliners,
I'm looking to upgrade my ECU for my ER34 (manual). Any recomendations on workshops who can do a good job? And based on your experience, which type/brand of ECU works best on this car?
Hope to hear...
Acura Advanced Sports Car Concept
The Next NSX?
http://img141.imageshack.us/img141/4376/122200718536ea2.jpg
Acura had an ace up its sleeve at the North American International Auto Show. To...
Main Forums
Interests
ICE
