Main Forums
Car Talk
Wheel bearings!
<blockquote data-quote="zendengoh" data-source="post: 2759147" data-attributes="member: 60459"><p>if the wheel bearing worn off, probably when moving sure got the "aeroplane sound", go more faster the sound will be more louder.</p></blockquote><p></p>
[QUOTE="zendengoh, post: 2759147, member: 60459"] if the wheel bearing worn off, probably when moving sure got the "aeroplane sound", go more faster the sound will be more louder. [/QUOTE]
Evo 1 2 3 ECU Chipping
Following are some information on how to chip a evo 1 2 3 ecu.
You need to get the ecu out of the car and open up the casing.
Inside you will see this PCB... it already has a standard chip in it...
Urgently need advice on haltech...
Dear bros,
My car has been in garage for 2 weeks but still can't troubleshoot what happened. I'm using haltech e6x, while driving slowly the car suddenly "pop" and have some black smoke. After that can't start at...
White Smoke on 93T
Hi buddies,
Need help from you guys to tackle my 93T problem.
Sometimes it has white smoke somtimes its gone.
I could see through my rear view mirror.
What is my problem?
Turbine?
Main Forums
Car Talk
Wheel bearings!
