Main Forums
General Talk
Wheel balancing and Alignment question
<blockquote data-quote="FVel" data-source="post: 2516587" data-attributes="member: 48425"><p>Speaking of messing around with cambers, do any of you actually do this to your daily rides ? </p><p></p><p>I'm certainly no expert but I was always under the impression doing something like this is probably more suited for track use where suspension settings are tweaked to get the best out of each specific track. Car setup to me is something of a black art if you are just a casual enthusiast, even more so if you don't really know what you are doing. </p><p></p><p>Furthermore, in regards to the comment above, does -ve camber necessarily give you more stability ? Wouldn't this change the tyre contact patch as well ? As a result, wouldn't you need to adjust tyre pressures to non-standard levels after changing camber ?</p></blockquote><p></p>
[QUOTE="FVel, post: 2516587, member: 48425"] Speaking of messing around with cambers, do any of you actually do this to your daily rides ? I'm certainly no expert but I was always under the impression doing something like this is probably more suited for track use where suspension settings are tweaked to get the best out of each specific track. Car setup to me is something of a black art if you are just a casual enthusiast, even more so if you don't really know what you are doing. Furthermore, in regards to the comment above, does -ve camber necessarily give you more stability ? Wouldn't this change the tyre contact patch as well ? As a result, wouldn't you need to adjust tyre pressures to non-standard levels after changing camber ? [/QUOTE]
Nissan Stealth
Nissan Stealth: The BNR34 Nissan Skyline GT-R Test Car
What seemed to be an ordinary BCNR33 GT-R to onlookers was in actual fact an...
Exhaust system Spec - Evo7
Sifus,
Kindly enough to share the set up u having and what is the best specification, no modification on engine. custom or branded HKS, APEXI, Greddy etc
Appreciate the suggestions and reccomendations. TQ
To all that wanted to earn extra poket money..., If u have a broadband.
Hey guys if u want to earn an extra poket money click in this side n the register it. Not lie one... Trust me...
Main Forums
General Talk
