Main Forums
Interests
ICE
What's the charges like?
<blockquote data-quote="Pjam" data-source="post: 1534089" data-attributes="member: 14038"><p>that is a very basic installation.. should not be as high as RM500 for tuning+installation.. unless u are using higher end cables, distribution block...</p><p>read the amp's + headunit's manual, try to DIY tuning, its not as complicated as u think</p></blockquote><p></p>
[QUOTE="Pjam, post: 1534089, member: 14038"] that is a very basic installation.. should not be as high as RM500 for tuning+installation.. unless u are using higher end cables, distribution block... read the amp's + headunit's manual, try to DIY tuning, its not as complicated as u think [/QUOTE]
david tao
Budget tyres - Dayton, Landsail, Sportiva, Thunder, etc
I usually allow a budget at RM1500-RM1600 for changing 4pcs tyres 225/45/18.
Came across with so many budget tyres in the market nowadays.
I wonder how can tyre manufacturer sell those tyres at a really cheap price...
Mr2 Specialist
Hi folks,
Looking to buy a MR2, can anyone point me to the right direction to a MR2 specialist mechanic. In case I need to send one for pre-purchase evaluation.
BTW, for things like shocks, brake pads & disks...
EMS400 ECU pin-out
CHAPTER ONE:
EMS 400 ECU pin out (terminal assignment)
Introduction: EMS 400 ECU from Siemens VDO has two sectors called ECU1 and ECU2, with 120 pin terminals in total. Only 45 are used for SVDO 4G13/15...
Main Forums
Interests
ICE
