Main Forums
Interests
Do-It-Yourself Garage
What use for Crossover
<blockquote data-quote="cacin" data-source="post: 1822712" data-attributes="member: 10222"><p>If it is a passive x-over, you can't do much since there's no way to separate the 5 way 6 x 9. However, as edlim suggested, use low pass of your amp to the woofer, use highpass of the amp to your 6x9 ( you can also off it, full range or flat). The design on the 6 x 9 should handle the signal for each of the 5 driver in the 6 x 9.</p></blockquote><p></p>
[QUOTE="cacin, post: 1822712, member: 10222"] If it is a passive x-over, you can't do much since there's no way to separate the 5 way 6 x 9. However, as edlim suggested, use low pass of your amp to the woofer, use highpass of the amp to your 6x9 ( you can also off it, full range or flat). The design on the 6 x 9 should handle the signal for each of the 5 driver in the 6 x 9. [/QUOTE]
New Exige 380 is Lotus' most Extreme Road Car!
There's a new Exige, named the Exige Sport 380. With 375hp and 410Nm on tap, the car is now 30hp and 10Nm up the Exige Sport 350...
safc 5 button on L2
hi all..does anyone know how to set the car select and type select at the back of the safc 5 button for mira L2? tq
Friday, 4th January 2008, 9.30 pm Skyline Gathering .
2008 - Skyline Gathering .
When?
Where?
9.30 pm. Meet at Sunway FoodCourt, Meet and get to know each other
10.30 pm - (A) A drive to Genting Highland, have tea at Gotong...
Main Forums
Interests
