my fren drivin wira aeroback SE and she found this thing on the carpet behind the driver seat.
i dunno where should put back this things and what its call :ph34r: . hope all the sifu out there can help.
this is the cover to the air purifier/ioniser in the car la. The unit is either behind the rear passenger seats on top there, or below the driver area under steering wheel, etc.etc just look around.
but really found behind the passenger seat wo.....?? but i have try to look around..but find nothing....nvm...i try to look for it again...anyway thanks for all the sifu reply
My dad drives a perdana SEI that's the air filter cover for the build in air purifier in the car lah. If your car doesn't have it that means it drop out from another car lor.
hi all,
now my car reach change ATF oil time already. do you all have change the ATF oil filter together?
i know have some car model is use metal mesh filter so do not change it. so how our airtrek?
and i bought...
I'm currently using sports abs + sport springs.. before was using standard abs with the same sets of springs.. the problem is before i change into the sport abs there knocking sound on the right side of the abs...
i noticed that my altezza's belts are suffering some wear and tear condition (rubbers starts to peel off) and my friend suggested that i should change the belts........:X-:
