Main Forums
Interests
ICE
what the diff between sealed box sub and non sealed box??
<blockquote data-quote="energie" data-source="post: 723079" data-attributes="member: 3992"><p>Ahhh, here's another. The search for the absolute enclosure continues .... hehehe. </p><p>Jack, put it this way,if you want your bass to be accurate & loud, you'd go with sealed, reason is that it is very easy to build & the Qtc of sealed could be chosed easily. Vented will definitely give you louder bass at port tuning but the Q is not variable. Variations in the vented's Q would cause increment & decrement in bass which is also known as misalignment, which would cause the bass from the vented being too boomy. This is where usually the vented box falls short in favour for SQ. If you could get past all the trouble the vented can present you, yeah you could get great SQ from it why not.</p><p>You would also want to consider what kind of shape you want the enclosure to be, this is something a lot of ppl tend to overlook. I'll share with you the summation of enclosure shape variations.</p><p></p><p>Sphere : +- 0.5db</p><p>Beveled Cube : +-1.5db</p><p>Beveled Rectangle : +-1.5db</p><p>Rectangle : +-2db</p><p>Cube : +-5db</p><p></p><p>Stay away from cube shaped enclosure, in short, it'll give you too much standing waves, sure you could fill the enclosure, but you wouldn't want to overdamp it. Sphere shaped enclosure is definite,but it is very hard to construct, you could get it from Focal, they had manufactured an egg-shaped enclosure. But the easiest is to stick to beveled enclosure, or some would call it wedge. Be very sure to get a pro installer to do it for you, most of the shops out there knows nuts abt what they're doing.</p><p>Oh yeah, stay away from bandpass.</p></blockquote><p></p>
[QUOTE="energie, post: 723079, member: 3992"] Ahhh, here's another. The search for the absolute enclosure continues .... hehehe. Jack, put it this way,if you want your bass to be accurate & loud, you'd go with sealed, reason is that it is very easy to build & the Qtc of sealed could be chosed easily. Vented will definitely give you louder bass at port tuning but the Q is not variable. Variations in the vented's Q would cause increment & decrement in bass which is also known as misalignment, which would cause the bass from the vented being too boomy. This is where usually the vented box falls short in favour for SQ. If you could get past all the trouble the vented can present you, yeah you could get great SQ from it why not. You would also want to consider what kind of shape you want the enclosure to be, this is something a lot of ppl tend to overlook. I'll share with you the summation of enclosure shape variations. Sphere : +- 0.5db Beveled Cube : +-1.5db Beveled Rectangle : +-1.5db Rectangle : +-2db Cube : +-5db Stay away from cube shaped enclosure, in short, it'll give you too much standing waves, sure you could fill the enclosure, but you wouldn't want to overdamp it. Sphere shaped enclosure is definite,but it is very hard to construct, you could get it from Focal, they had manufactured an egg-shaped enclosure. But the easiest is to stick to beveled enclosure, or some would call it wedge. Be very sure to get a pro installer to do it for you, most of the shops out there knows nuts abt what they're doing. Oh yeah, stay away from bandpass. [/QUOTE]
david tao
any r34 gtt for continue payment loan?
any r34 gtt for continue payment loan? any offer? mail me
[email protected]
. thanks. problem with bank loan.
Nissan GT-R : First Drive in Japan
What is it?
Well for starters, it’s not the new Skyline GT-R. Instead it’s referred to merely as the Nissan GT-R. The name Skyline is no...
is it enable reduce 12v to 1.5v?
just now i go to pasar malam,i saw a LED stuff like the branded PIAA 6 LED in line and cost around rm400,it plastic quite bright n got 2 option,1 is flashing and others is keep it on,5 LED in line,the purpose of this...
Main Forums
Interests
ICE
