Main Forums
Car Talk
what shud i get ...
<blockquote data-quote="popiah" data-source="post: 154065" data-attributes="member: 2369"><p>something mild like meguiar's paint cleaner, if cannot, then mayb soft99 or kit wax and turtlewax, those are more aggresive than meguiars and if not used properly will cause swirls on your car finish. if not try scratchX rr try bug and tar remover.</p><p></p><p></p><p>One point to note, it has been 4 months, your paint might be etched liao. So might take multiple applications to remove. So patience is the key.</p><p></p><p>If all these mild items dun help, then time to get a machine and attack it with Meguiar's DACP or compound or wet sanding to remove it liao.</p><p></p><p>So lets hope your paint is not etched. If it is, only the last few methods will help. :P</p></blockquote><p></p>
[QUOTE="popiah, post: 154065, member: 2369"] something mild like meguiar's paint cleaner, if cannot, then mayb soft99 or kit wax and turtlewax, those are more aggresive than meguiars and if not used properly will cause swirls on your car finish. if not try scratchX rr try bug and tar remover. One point to note, it has been 4 months, your paint might be etched liao. So might take multiple applications to remove. So patience is the key. If all these mild items dun help, then time to get a machine and attack it with Meguiar's DACP or compound or wet sanding to remove it liao. So lets hope your paint is not etched. If it is, only the last few methods will help. :P [/QUOTE]
david tao
The saga continues: 1 Malaysia Racing takes Group Lotus to court
https://www.zerotohundred.com/wp-content/uploads/2010/09/Lotus-Racing-F1.jpg
The Group Lotus vs Team Lotus saga continues with a cool yet snarling statement from the CEO of Lotus Racing Riad Asmat.
It all started...
Speed bump & stock 350z
So what's the fatality rate of stock 350z's bodykit when driven here in Malaysia? Since it is not too low, I assume there won't be too much troubles going over speed bumps. The wheelbase is long though, so my...
Check Light after Emanage Installation
Hi all,
I'm currently on a CE9A (Evo 3) running stock setup except 2.5" downpipe and 3" piping behind, an open pod and avcr running max 1 bar.
Everything is fine.
Just installed Emanage (Blue) with full harness...
Main Forums
Car Talk
what shud i get ...
