Car Clubs
Car Club Categories
The Cefiro Club Malaysia
What is side slide?
<blockquote data-quote="Lawcc" data-source="post: 2142687" data-attributes="member: 15652"><p>Thanks Bob again. You triggered me to do Goggle search and this is what I found.</p><p></p><p>"If Automobile front-wheel drive (steering wheel) toe-in is not fit with camber angle, automobile will broadwise sideslip when auto is going. It's called wheel sideslip. The wheel sideslip will directly influence tire wear degree and steer handiness. KSC-101 Automobile sideslip tester especially test the wheel sideslip, it is the necessary equipment to assure the auto steer handiness. "</p><p></p><p>Not all the alignment shop has the machine to check this.</p></blockquote><p></p>
[QUOTE="Lawcc, post: 2142687, member: 15652"] Thanks Bob again. You triggered me to do Goggle search and this is what I found. "If Automobile front-wheel drive (steering wheel) toe-in is not fit with camber angle, automobile will broadwise sideslip when auto is going. It's called wheel sideslip. The wheel sideslip will directly influence tire wear degree and steer handiness. KSC-101 Automobile sideslip tester especially test the wheel sideslip, it is the necessary equipment to assure the auto steer handiness. " Not all the alignment shop has the machine to check this. [/QUOTE]
Too high tire pressure can cause body vibration?
Recently I exchanged cars with my mother for me to use in KL, Proton Wira with 185/60 R14 tires (or maybe its 195/50/R15, not too sure but its either one of these). When driving between 80-90kph, I can feel the car...
ralliart side mirror for CT9A
anyone
brake lines
Guys,
Got few units of new ralliart brake line for E6 and E7 lines for sale. RM750 each.
TQ...cheers
Car Clubs
Car Club Categories
What is side slide?
