Car Clubs
Car Club Categories
MAC : Malaysia Airtrek Club
Weird Serpentine belt problem.
<blockquote data-quote="Salmaan" data-source="post: 1064228628" data-attributes="member: 75945"><p>The belt is alot shorter, so even if i remove a pulley run the belt and then attempt to return the pulley it will not go in, i had sliding the belt over the crank pulley abit then rotating the crank pulley to get the belt on, wouldnt work and starting cutting the belt. </p><p>I just have the one belt, the original one i tossed a long time ago as it had worn out, thats when i ordered this one.</p><p>A shop here has the 6PK 1880 belt will try that one today, if it fits (hopefully it will as its the longest one they have).but i still cant wrap my head around why the old one cannot fit.it is alot shorter and doesnt even get to the lip of the crank pulley, even after pushing the tensioner all the way back.</p><p></p><p>If it does fit should be cranking it by this weekend. will post some pics of the engine compartment.</p></blockquote><p></p>
[QUOTE="Salmaan, post: 1064228628, member: 75945"] The belt is alot shorter, so even if i remove a pulley run the belt and then attempt to return the pulley it will not go in, i had sliding the belt over the crank pulley abit then rotating the crank pulley to get the belt on, wouldnt work and starting cutting the belt. I just have the one belt, the original one i tossed a long time ago as it had worn out, thats when i ordered this one. A shop here has the 6PK 1880 belt will try that one today, if it fits (hopefully it will as its the longest one they have).but i still cant wrap my head around why the old one cannot fit.it is alot shorter and doesnt even get to the lip of the crank pulley, even after pushing the tensioner all the way back. If it does fit should be cranking it by this weekend. will post some pics of the engine compartment. [/QUOTE]
david tao
Simple changing driveshaft boot with a cone
Instead of the conventional way of changing the boot by removing the whole driveshaft, and then whacking out the CV joint, I used a simpler way to get the boot onto the cv joint. Note: This method should only be used...
Max limit for TD04L turbo
Closed
Hi, is anybody tried the max boost using TD04L on a 1834cc engine at 7.5k RPM? Is it possible to get 1.1bar at 7.5k RPM? Will it kill the turbo?
apexi exhaust system
i have a set R34 apexi hybrid.exhaust system for sell rm1000...like new ..
call me 0124893661 n r34 standard turbox2 rm1400
david tao
Car Clubs
Car Club Categories
