Car Brands
Car Manufacturers
Proton
Weird problems on my Waja...
<blockquote data-quote="sakuraguy" data-source="post: 1684043" data-attributes="member: 6441"><p>vyruzj: Some may faced this problem, at the first D.I.Y technique, refer below:</p><p></p><p>1. Check ure engine oil level - Is it in the appropriate level ?</p><p>2. Check ure battery fluid level and its capacity level (In Voltage) .. normally 12volts and above + -</p><p>3. Turn off the engine and DISCONNECT the battery POSITIVE (+) terminal of ure Waja and leave it for 1 or 2 minute, at this time press ure BRAKE pedal to discharge the voltage running inside ure car (BRAKE is the only way to discharge reserved voltage charges).</p><p></p><p>Put back the POSITIVE (+) terminal and start ure car, make sure u insert the key and turn to IGNITION .. wait for 1 or 2 minutes before STARTING the car .. this will start ure car with a refreshed ECU setting from the factory ROM.</p><p></p><p>Always dont immediate start ure Waja, ... always insert the key and turn to IGNITION .. wait for 1 or 2 minutes before STARTING the car.</p><p></p><p>If the problem still persists, please consult Proton service centre.</p><p></p><p></p><p>Good Luck ..</p></blockquote><p></p>
[QUOTE="sakuraguy, post: 1684043, member: 6441"] vyruzj: Some may faced this problem, at the first D.I.Y technique, refer below: 1. Check ure engine oil level - Is it in the appropriate level ? 2. Check ure battery fluid level and its capacity level (In Voltage) .. normally 12volts and above + - 3. Turn off the engine and DISCONNECT the battery POSITIVE (+) terminal of ure Waja and leave it for 1 or 2 minute, at this time press ure BRAKE pedal to discharge the voltage running inside ure car (BRAKE is the only way to discharge reserved voltage charges). Put back the POSITIVE (+) terminal and start ure car, make sure u insert the key and turn to IGNITION .. wait for 1 or 2 minutes before STARTING the car .. this will start ure car with a refreshed ECU setting from the factory ROM. Always dont immediate start ure Waja, ... always insert the key and turn to IGNITION .. wait for 1 or 2 minutes before STARTING the car. If the problem still persists, please consult Proton service centre. Good Luck .. [/QUOTE]
david tao
How I DIY my factory Clarion HU to pioneer
Hey guys, just thought i should share how i DIY my head unit in case any of you need to..
Firstly since we dont have the bloody key to release the HU
http://i204.photobucket.com/albums/bb11/ryan_hustler/Step1.jpg...
Different Between ACD & AYC (On Evo7)
Guys,
Most likely will get my E7 early next week...suppose esok but thern tak sempat!!
Anyway, i just notice that the 4WD button on the right side (near the signal controller/steering) stated ACD, not AYC. Suppose...
Dream Auto Fiesta, January 8th 2006 -- Drift In Style!
Dear Drift Aficionados,
In conjunction with DREAM AUTO FIESTA, 2006, organised by the Engineering Students Society of IIUM, dubtechniques and ARMedia Group, we are trying to feature a drifting competition cum...
david tao
cjkang
Car Brands
Car Manufacturers
Proton
