Car Brands
Car Manufacturers
Toyota
Weird Engine
<blockquote data-quote="ayathu" data-source="post: 1063841572" data-attributes="member: 49498"><p>Bro since it happens only during engine cold than the logic thing to check will be contacts for</p><p></p><p>example your key ignition( its actual a switch so got contact inside it), battery termination, </p><p></p><p>alternator termination. Try checking these, who knows that might be the problem, cause this</p><p></p><p>happened to my brothers civic FD, the battery +ve terminal was loose, the engine die off </p><p></p><p>intermittently, after tighten terminal problem solved.</p></blockquote><p></p>
[QUOTE="ayathu, post: 1063841572, member: 49498"] Bro since it happens only during engine cold than the logic thing to check will be contacts for example your key ignition( its actual a switch so got contact inside it), battery termination, alternator termination. Try checking these, who knows that might be the problem, cause this happened to my brothers civic FD, the battery +ve terminal was loose, the engine die off intermittently, after tighten terminal problem solved. [/QUOTE]
R35 Used Titanium Exhaust
NZ Wheels - Spin it For Another Mercedes-Benz!
NZ Wheels are looking to provide 164 lucky customers the chance to win incredible prizes, and one of them...
Speedometer Problem
Hi! Got problem :cry_smile: with my speedo, going crazy everytime I hit a something or I make a sharp left turn, it goes crazy.
Anyone with similar experiences and any remedies besides changing the whole meter cluster?
Anyone know how to convert psi to kg/cm
sn964444
Car Brands
Car Manufacturers
Toyota
Weird Engine
