Main Forums
General Talk
way to matspeed...
<blockquote data-quote="minivan" data-source="post: 1122537" data-attributes="member: 3299"><p>not that good at describing its location... he goes nwayz</p><p></p><p>if you are from the Proton factory heading to shah alam, after the traffic lights of the KESAS hiway, there a petronas station on your right. Behind the petronas station theres a row of shop / kilang that is facing an open field. Its at the end lot.</p><p></p><p>true right guys..?? :_:</p></blockquote><p></p>
[QUOTE="minivan, post: 1122537, member: 3299"] not that good at describing its location... he goes nwayz if you are from the Proton factory heading to shah alam, after the traffic lights of the KESAS hiway, there a petronas station on your right. Behind the petronas station theres a row of shop / kilang that is facing an open field. Its at the end lot. true right guys..?? :_: [/QUOTE]
david tao
ARC Super Induction Air Filter Box..Very Light & Tip-Top Condition
Pls Check The Link Below
http://www.zerotohundred.com/newfor...ter-box-very-light-and-tip-top-condition.html
TQTQ
Evo 4 gearbox and Evo 6 gearbox
just to ask is there any diff for evo4 and evo6 gearbox?
Daihatsu L6 ECU Diagnostic Code
Hi all,
I am facing a problem with my L6 ECU, I transplant the ECU to my Kenari EJDE Engine (Bolted On Turbo). Can start, but the engine check light doesn't off. :cry_smile: So I checked the diagnostic codes:
i) 8...
Main Forums
General Talk
way to matspeed...
