it think dry ice ic uses less components..
but i dont think it is suitable for daily use
stock is the best
heh heh
stock is the best
heh heh
Don't apologise for posting your own opinion. If everyone is afraid of posting their opinion we will all not be able to develop & enhance their knowledge.eyong said:I have used water-to-air intercooler before from an original works Toyota Celica GT-4 .... It was a great concept during the early 90's of WRC and some Le-Man's cars. It definately has a weight penalty for the amount of plumbing, water, pump, core to soak the charge air, and another core to cool the water within the system. No doubt the charge air plumbing is shorter, however, with modern intercooler, there's hardly any known pressure drops.
This is where using an igloo or thermos-type tank is better as it regulates the temp a bit more. But I guess for drag-race usage it is fine. Seriously, the temperature makes a BIG difference. I once watched a car using a water-to-air system being tuned on a dyno. Using normal tap water, a certain HP rating was reached. Just by simply adding ice cubes to the water, the HP rating increased by another 60HP!!!normalilty78 said:actually what my mech did on his drag car was using a normal plastic container, drill hole on it. thn using those fish tank water pump to pump the water around.
however, there is some cautions (this is what my mech faced). 1st thing is irregular intake temp. as he is using ice cubes to cool the water, hence the intake temp can be abit flactuate. so whn tuning and actual drag running may have abit problem.
RSI said:I have Spearco 2-231 liquid to air cooler if anyone is interested.http://www.turboneticsinc.com/ic_liquidtoair.htm
jo1 said:are you the dealer or individual seller..... i'm interested but not that size....:secret: do you have the water pump as well...
RSI said:Also during start stop start stop situation the water to air cooler works much better as there is not enough time for air to flow round an air to air cooler. This effect is even more noticeable especially on top mount setups such as 4AGZE, Mira Turbos, Subaru Imprezzas and GT4 celicas. If you blast the car between a series of traffic lights you will feel the car loses quite a bit of power as the charge air becomes hot. Interheater it becomes!
normality78 said:hm... abit on ICE topic here.
i found out on my mech drag machine, if we use the big ice block, the ice block do last longer thn small ice cube but it doesnt cool the water fast enaugh.
but on small ice cube, it does cool the water very fast but also will melted very fasy. does dry ice benefit in both way? meaning last longer and cool faster?
RSI said:Dry ice has a surface temp of -78 degrees C
Ice has a surfac temp of 0 degrees C
Hmmm.....so if dry ice converts to gas, doesn't that mean the gas will be used in the cooling process then be converted to nothing but hot air? Whereas if water is used, at least it is in liquid form and while the cooling effect is definitely lesser, at least it remains? So we can surmise that dry ice is only adequate for short term usage such as drag racing.RSI said:Water Ice melts from solid to liquid.
Dry Ice is actually solid carbon dioxide
It subliminates: meaning it goes from solid straight to gas ithout becoming liquid.
Tires Become Latest Chinese Product to Threaten...
