Main Forums
Car Talk
water temp shooting skyhigh
<blockquote data-quote="taukey" data-source="post: 1285271" data-attributes="member: 19177"><p>sad to hear that...2 days ago i sent my car to workshop, i told them that my tank water and radiator water level decreasing everyday..normal car fill up the fuel but my car fill water everyday ehehe..then they clean my radiator, check my master water pump..hosts and they didnt find any leaking water..then that pomen said maybe the gasket head..</p><p></p><p>B4 this, my timing belt loose and 4 out of 16 valve gone..and changed the gasket head and whatever belong to that damage...</p><p></p><p>For ur information, the pomen also change the radiator cap (new one)...and today i check no leaking under my car..but the water tank EMPTY and radiator level decrease a bit..the temperature level almost reach 1/2...then I read this topic and I think what pomen said about GASKET was rite...tomorrow i;ll sent my car again..i hope that gasket not really damage..last time it was so expensive cost to replace that..any other suggestion..plz help me..</p><p></p><p>addition: my friend said when i speeding at gear 1,2 they saw a smoke...donno la which smoke..white or black..probably white bcoz last time ago i saw when i start my car in the morning..white smoke appear....then here is the QUESTION: "well if your radiator losing water frequently....try check the head gasket as well if there is no leakage from the pipings " --> which GASKET u mean...HEAD GASKET or RADIATOR GASKET. Help me plz...</p></blockquote><p></p>
[QUOTE="taukey, post: 1285271, member: 19177"] sad to hear that...2 days ago i sent my car to workshop, i told them that my tank water and radiator water level decreasing everyday..normal car fill up the fuel but my car fill water everyday ehehe..then they clean my radiator, check my master water pump..hosts and they didnt find any leaking water..then that pomen said maybe the gasket head.. B4 this, my timing belt loose and 4 out of 16 valve gone..and changed the gasket head and whatever belong to that damage... For ur information, the pomen also change the radiator cap (new one)...and today i check no leaking under my car..but the water tank EMPTY and radiator level decrease a bit..the temperature level almost reach 1/2...then I read this topic and I think what pomen said about GASKET was rite...tomorrow i;ll sent my car again..i hope that gasket not really damage..last time it was so expensive cost to replace that..any other suggestion..plz help me.. addition: my friend said when i speeding at gear 1,2 they saw a smoke...donno la which smoke..white or black..probably white bcoz last time ago i saw when i start my car in the morning..white smoke appear....then here is the QUESTION: "well if your radiator losing water frequently....try check the head gasket as well if there is no leakage from the pipings " --> which GASKET u mean...HEAD GASKET or RADIATOR GASKET. Help me plz... [/QUOTE]
david tao
grill mod
So i decided to cut my original grill i dont think it looks that bad . But if your going to do this the only thing i can say is TAKE YOUR TIME
Silence Strip Review
This Door Silence Strip
This post is taken from Pocket Rocket(White CRZ with gold XXR). He deserves all the credits and I have
asked for permission.
This strip is to reduce wind noise and make better contact...
Evo 8 Meter Cluster Bulbs
Does anyone where am I able to get those Speedometer bulbs for Evo 8? prefebly led ones. Mine's almost all gone :hmmmm:
Main Forums
Car Talk
