Car Brands
Car Manufacturers
Toyota
Water in boot area....
<blockquote data-quote="km_chew" data-source="post: 4453038" data-attributes="member: 4354"><p>The hole is on the left and right side of the boot too .. It's for the sunroof water hose to go thru .. If you don't have sunroof, it is suppose to be covered with a plastic plug.</p></blockquote><p></p>
[QUOTE="km_chew, post: 4453038, member: 4354"] The hole is on the left and right side of the boot too .. It's for the sunroof water hose to go thru .. If you don't have sunroof, it is suppose to be covered with a plastic plug. [/QUOTE]
Upgrade For Perdana 4g63T RVR
Hello to all..im new to this forum...would like to make new frenz and share knowledge...
I have a Perdana Rvr 4g63T Auto..completely stock..and i never use turbo engine bfore..
So what can i do to upgrade power abit...
Brake Dilemma
Well turns out I'm gonna be needing a new pair of front rotors. Currently have Endless 6pots up front with the 355mm. I had previously asked around for prices maybe a year ago and they were in the RM3k range per pair...
Where to find check valve??
Guys,
Anyone knows where to buy check valve? also known as 1 way valve?? for air..
Also, where can i get copper piping?? around 10mm diameter
Car Brands
Car Manufacturers
Toyota
