Main Forums
Car Talk
Forced Induction & Engine Management
water-air intercooling
<blockquote data-quote="speedchaser" data-source="post: 141850" data-attributes="member: 5171"><p>I'd used a Jabsco Centri-Puppy which is kinda bloody expensive here but it does the job. Have to remember that when you boost, you have to make sure the pump is capable of flowing the heated water to the heat exchanger. BTW the water temp can rise to 80+C on some occasion depending on the efficiency of your turbo. If you are using the SC with a bigger pulley (175mm) the heat is enormous. I've blown 2 pumps on my learning curve that's how I know. When you plan for a pump, do not be mislead with the how much pressure the pump is capable of, for what you need is a good flowrate of at least 40gpm and above.</p><p></p><p>When you plan the flow structure, make sure the charge cooler is at the highest point in of the flow and make sure there's bleeding valve in place in the cooler. The water flow should go from bottom of the heat exchanger to the top to prevent bubbles. You can never guess what a little bubbles can wreak havoc to your temp.</p><p></p><p>Intercooler is meant for flowing air, yet theoritically in fluid dynamics it shouldn't be a problem but I would still prefer a custom made aluminium core which should be more than 600sq inch to start with.</p></blockquote><p></p>
[QUOTE="speedchaser, post: 141850, member: 5171"] I'd used a Jabsco Centri-Puppy which is kinda bloody expensive here but it does the job. Have to remember that when you boost, you have to make sure the pump is capable of flowing the heated water to the heat exchanger. BTW the water temp can rise to 80+C on some occasion depending on the efficiency of your turbo. If you are using the SC with a bigger pulley (175mm) the heat is enormous. I've blown 2 pumps on my learning curve that's how I know. When you plan for a pump, do not be mislead with the how much pressure the pump is capable of, for what you need is a good flowrate of at least 40gpm and above. When you plan the flow structure, make sure the charge cooler is at the highest point in of the flow and make sure there's bleeding valve in place in the cooler. The water flow should go from bottom of the heat exchanger to the top to prevent bubbles. You can never guess what a little bubbles can wreak havoc to your temp. Intercooler is meant for flowing air, yet theoritically in fluid dynamics it shouldn't be a problem but I would still prefer a custom made aluminium core which should be more than 600sq inch to start with. [/QUOTE]
Test: 2006 Audi A4 2.0T FSi
TEST: AUDI B7 A4 TFSi
Photography: Tom Goh
Words: Jason
Hks Pfc Fcon
anyone tried hks pfc fcon here b4? i have some question to ask.. can i change the map sensor(fcon) to diff. brand of map sensor such as microtech 25psi map sensor?
DIY SUPERCHARGER
I plan to install a Nissan March K10 supercharger into my Gen2. Has anyone done such DIY supercharger projects b4?
Main Forums
Car Talk
