Main Forums
General Talk
wat is the use of.....?
<blockquote data-quote="soggie" data-source="post: 1086293" data-attributes="member: 6245"><p>If you're not careful its easier to bend your rims when you hit potholes. Other than looking good, lower sidewall means stiffer sidewall means less flex on heavy corner g-forces. I think this should mean better handling on high speed turns.</p></blockquote><p></p>
[QUOTE="soggie, post: 1086293, member: 6245"] If you're not careful its easier to bend your rims when you hit potholes. Other than looking good, lower sidewall means stiffer sidewall means less flex on heavy corner g-forces. I think this should mean better handling on high speed turns. [/QUOTE]
david tao
super advan racing 18"
i have a set of advan racing rim... size 18' x 9j x 22 offset
with trye.... rm 2900
intrested sms or call me... 0122810008
Can GT-R be a daily use car?
i've previously never owned any sport car before, and this is a twin turbo car.
Now, planning on getting 1, and that's gt-r 34, it's power and look that just blow me away. but i'm concerned about the durability of...
Turbo Manifold Glow
Is it normal for the manifold to glow
Mine glows if i booost 1bar
if i boost 0.7 it looks fine
What does that glowing mean ?
What to do ?
thanks
Main Forums
General Talk
