Car Brands
Car Manufacturers
Honda
Vtec timing problems >> Need Views
<blockquote data-quote="J101" data-source="post: 2675869" data-attributes="member: 15660"><p>dying fuel pump - check fuel pressure</p><p></p><p>dying spark plugs - check spark plugs</p><p></p><p>loose ecu harness - pull and insert back</p><p></p><p>dirty IACV/throttlebody - clean them</p><p></p><p>dying distributor - check the coil and ignitor</p><p></p><p>clogged injectors - injector clean up</p></blockquote><p></p>
[QUOTE="J101, post: 2675869, member: 15660"] dying fuel pump - check fuel pressure dying spark plugs - check spark plugs loose ecu harness - pull and insert back dirty IACV/throttlebody - clean them dying distributor - check the coil and ignitor clogged injectors - injector clean up [/QUOTE]
R35 Used Titanium Exhaust
new tyre in front or rear?
I'm curious.
I did some search and it seems there's a mix of information.
In the western, they are putting the new tyres at rear.
Reason being is they believe new tyres on the rear axle help the driver more easily...
supercharger Repair
Hi everyone , i wanna ask where can repair or rebiuld supercharger shop ?
AC Schnitzer goes Green with 552bhp LPG V10 E92 - ACS GP3.10
Driving pleasure has been written large at AC Schnitzer for 20 years. And happily, nothing will change for...
Car Brands
Car Manufacturers
Honda
