Car Brands
Car Manufacturers
Honda
vtec setting
<blockquote data-quote="rakyat" data-source="post: 4494469" data-attributes="member: 74468"><p>Just tekan the button and the ecu will switch gears at higher rpm, whether there is indicator or not nvm just cosmetic. You can change to an auto dashboard and do the wiring but cost money w/o increasing power = waste money<img src="https://zerotohundred.com/forums/styles/default/xenforo/smilies/biggrin.gif" class="smilie" loading="lazy" alt=":biggrin:" title="Biggrin :biggrin:" data-shortname=":biggrin:" /> </p><p></p><p>Unless u rechip ur ECU, the OEM has a speedcut @ 180 km/h even if the meter can go up to 220 km/h (i think applicable to all Japo imports, CBU or halfcut engines, if ckd then mayb no speedcut)</p><p></p><p>CEL y need to check? If the 'check engine' light is on you definetly can see it when driving; you can also feel you can being sluggish. Just do what I mention (flooring the accelerator) and see whether there is any effect after 5k rpm feel Vtec engage or not.</p></blockquote><p></p>
[QUOTE="rakyat, post: 4494469, member: 74468"] Just tekan the button and the ecu will switch gears at higher rpm, whether there is indicator or not nvm just cosmetic. You can change to an auto dashboard and do the wiring but cost money w/o increasing power = waste money:biggrin: Unless u rechip ur ECU, the OEM has a speedcut @ 180 km/h even if the meter can go up to 220 km/h (i think applicable to all Japo imports, CBU or halfcut engines, if ckd then mayb no speedcut) CEL y need to check? If the 'check engine' light is on you definetly can see it when driving; you can also feel you can being sluggish. Just do what I mention (flooring the accelerator) and see whether there is any effect after 5k rpm feel Vtec engage or not. [/QUOTE]
R35 Used Titanium Exhaust
Dynojet power commander for Campro CPS
Dynojet power commander can use on Campro CPS engine ???
CS3A convert to Evo 7 bodyparts front and Rear
Dear All Sifuss ..
Does anyone know where can I get a reasonable price for EVO 7 Bodyparts. I met accidents 4 months ago but now still sit in the workshop,
. Couldn't find the parts for CS3A in the...
Ori Evo 6 For Sale
Letting it go !
Engine fully rebuilt dyno provent 234hp on wheel when i was running at 0.8 bar, Titan shock absorber used 10 months...
sn964444
Car Brands
Car Manufacturers
Honda
vtec setting
