Main Forums
Car Talk
Car Modification
Vr4
<blockquote data-quote="sekkuttz" data-source="post: 1063809047" data-attributes="member: 126430"><p>Gentlemen,</p><p></p><p>I've inherited a Proton Wira VR4 from my brother and the engine condition is kind a working okay. But there are several problems occurs recently in the system (I think so) and I don't know what is it.</p><p></p><p>When I'm on accelerate and hit the clutch instantly (i.e change gear or slowing down), the engine will shut off. It happens often. Does it have to do anything with its throttle body? </p><p></p><p>Then the engine jerking when it hit >5500 rpm (boost @ 0.6) and now it happen @ >3500rpm(approx). Does it has anything to do with the turbo or fuel pump? Or anything else?</p><p></p><p>FYI, there's some leakage around the manifold area (white smoke coming out) when i rev the engine.</p><p></p><p>Need advice from the experienced on what really happen to the engine and what should i tackle first to get it at least okay to be used. My budget is not more than 2k currently (as I just started working) and I plan to set it to stock condition because I travel from selangor - melaka regularly.</p><p></p><p>Thank you and appreciate any comment & advice.</p></blockquote><p></p>
[QUOTE="sekkuttz, post: 1063809047, member: 126430"] Gentlemen, I've inherited a Proton Wira VR4 from my brother and the engine condition is kind a working okay. But there are several problems occurs recently in the system (I think so) and I don't know what is it. When I'm on accelerate and hit the clutch instantly (i.e change gear or slowing down), the engine will shut off. It happens often. Does it have to do anything with its throttle body? Then the engine jerking when it hit >5500 rpm (boost @ 0.6) and now it happen @ >3500rpm(approx). Does it has anything to do with the turbo or fuel pump? Or anything else? FYI, there's some leakage around the manifold area (white smoke coming out) when i rev the engine. Need advice from the experienced on what really happen to the engine and what should i tackle first to get it at least okay to be used. My budget is not more than 2k currently (as I just started working) and I plan to set it to stock condition because I travel from selangor - melaka regularly. Thank you and appreciate any comment & advice. [/QUOTE]
R35 Used Titanium Exhaust
wta: Lancer floor mats same as evo8 ?
i am looking for new floor mats, can i buy original Lancer floor mats, to fit into my evo8mr ? anyone knows ? pls say something, thanks.
4g93 engine vibration- newbie
hey whats up all- i have a 4g93 out of an eagle summit i just replaced head gasket and timing belt on. the engine runs great but vibrates at idle. Timing seems to be ok. I read that you can get the silent shaft 180...
where got junkyard?
hi everyone.. :D
where got junkyard?
different from halfcut shop
junkyard is where the car is already taken apart...
i wan to find some...
i think it will be good place to source our parts for our DIY project...
Main Forums
Car Talk
Car Modification
Vr4
