Main Forums
Car Talk
Car Modification
Voltage stabilizer & grounding cables
<blockquote data-quote="nathanraja45" data-source="post: 1063552931" data-attributes="member: 116354"><p>Bro check whether your battery charge is ok...try to see if ur alternator is charging your battery...Easiest way 2 know whether ur alternator is working is by disconnecting negative terminal of ur battery when its running...</p></blockquote><p></p>
[QUOTE="nathanraja45, post: 1063552931, member: 116354"] Bro check whether your battery charge is ok...try to see if ur alternator is charging your battery...Easiest way 2 know whether ur alternator is working is by disconnecting negative terminal of ur battery when its running... [/QUOTE]
david tao
Your Opinion: TD or Garret?
Hi there,
To all turbo sifus out there? Which turbo charger better? TD or Garret?
Thanks :_:
99' spec stuff
Hi guys....
Wondering how much is the 99 spec Front Bumper with lip & turn lamp and
99 spec Rear tail lights? Looks very cool. Do they have replica type?
NEED help..
Hey guys.. i m in the process of sellin my car. i shud be handing over my baby by this
week. When i do that, i ll be carless. So, the question is, what car or which car shud i get?
i m in a dillema with my missus...
Main Forums
Car Talk
Car Modification
