Car Clubs
Car Club Categories
The Altezza / IS200 / IS300 Forum
Vafc
<blockquote data-quote="cuscostrutbrace" data-source="post: 2367280" data-attributes="member: 3867"><p>Yes,the aim is the same,to vary the camshaft timing.But how it is done is different.</p><p></p><p>VTEC is simple on and off function.It is rpm triggered.VTEC is a cam changing variable valve timing.It changes to another cam when it engages.The amount of duration and lift (also timing) is determined by the camshaft itself.</p><p></p><p>VVT (not VVTi) is a cam phasing variable valve timing.It just adjust the opening and closing of the valve (the timing).It is rpm triggered and only varies the timing by fixed amount (like 15deg).</p><p></p><p>VVTi is also a cam phasing system but constantly varies the timing according to rpm range (say like between 0-15deg).Hence it is not rpm triggered.It is duty cycle controlled.</p><p></p><p>I-VTEC combines VVT/VVTi and VTEC together.</p><p></p><p>MIVEC is the same like VTEC,VANOS is the same like VVT/VVTi</p><p></p><p>For VVTi controller,i suggest Power Enterprise CAMCON CC-101</p><p></p><p>Just my 2cents,correct i'm wrong :-)</p></blockquote><p></p>
[QUOTE="cuscostrutbrace, post: 2367280, member: 3867"] Yes,the aim is the same,to vary the camshaft timing.But how it is done is different. VTEC is simple on and off function.It is rpm triggered.VTEC is a cam changing variable valve timing.It changes to another cam when it engages.The amount of duration and lift (also timing) is determined by the camshaft itself. VVT (not VVTi) is a cam phasing variable valve timing.It just adjust the opening and closing of the valve (the timing).It is rpm triggered and only varies the timing by fixed amount (like 15deg). VVTi is also a cam phasing system but constantly varies the timing according to rpm range (say like between 0-15deg).Hence it is not rpm triggered.It is duty cycle controlled. I-VTEC combines VVT/VVTi and VTEC together. MIVEC is the same like VTEC,VANOS is the same like VVT/VVTi For VVTi controller,i suggest Power Enterprise CAMCON CC-101 Just my 2cents,correct i'm wrong :-) [/QUOTE]
Subaru Impreza GC8
R35 Used Titanium Exhaust
lan evo 6......
hi,can i ask about the evo 6?
hows the car reliability? is car's engine parts expensive?
(im noob in cars ><)
What Excites You ?
Poll your dream turbo guys....
GT2871R
GT2835R
GT3037R
GT3076R
RB26 CF Spark Plug Cover for Sale
Brand new RB26 Carbon Graphite Spark Plug Cover for Sale.
Picture as below,
Please call Donny, 0123041723 for price.
Thank you.
david tao
Car Clubs
Car Club Categories
Vafc
