Main Forums
General Talk
V6 Gear Box damage
<blockquote data-quote="ckl7480" data-source="post: 1757209" data-attributes="member: 40979"><p>hi all,</p><p></p><p>I also install the ATF oil cooler. That is so good for V6 gear boxes,prevent over heat. If over heat will burn oil seal and clutch pad inside.</p><p></p><p>When u install the S/H gear boxes, it better just change the oil with normal flushing.</p><p></p><p>If you using M/C to flushing it, the workshop won't take care your G/B if any problem. Remember it.</p><p></p><p>It better go to specialist shop for service only. ( cost you few hundred only )</p><p></p><p>ATF m/c flushing also cost u RM200 more.</p><p>It better keep this budget to service the gear boxes,more pratically.</p><p></p><p>Just for sharing............No offense</p><p>Coz i love my perdana :shades_smile:</p></blockquote><p></p>
[QUOTE="ckl7480, post: 1757209, member: 40979"] hi all, I also install the ATF oil cooler. That is so good for V6 gear boxes,prevent over heat. If over heat will burn oil seal and clutch pad inside. When u install the S/H gear boxes, it better just change the oil with normal flushing. If you using M/C to flushing it, the workshop won't take care your G/B if any problem. Remember it. It better go to specialist shop for service only. ( cost you few hundred only ) ATF m/c flushing also cost u RM200 more. It better keep this budget to service the gear boxes,more pratically. Just for sharing............No offense Coz i love my perdana :shades_smile: [/QUOTE]
New FT-86 logo shows off Boxer engine
http://www.zerotohundred.com/?attachment_id=17154
Toyota’s upcoming rear-wheel drive sports car, developed in collaboration with Subaru, was always rumoured to be powered by a 2-liter boxer engine from Subaru. In...
::Brand new Garrett T3/T04E::
Hello sifus,
Any idea what is the price of a brand new Garrett T3/T04E turbocharger:
-with .48 A/R stage III with .50 T04E compressor
-with .63 A/R stage III with .50 T04E compressor
Thank you very much.
Remove Vios Roof Upholstery
Anyone knows how to remove it ?
Intend to insert heat insulation.
Main Forums
General Talk
V6 Gear Box damage
