Car Brands
Car Manufacturers
Toyota
Upgrading 20v
<blockquote data-quote="wllim5" data-source="post: 507380" data-attributes="member: 206"><p>Question 2:</p><p></p><p>It uses 2 ECU mainly because is want to run 2 bank of 4 injectors which totally of 8 injectors. 2 injector/ cylinder. Running 2 ECU can run both injector in different map. Maybe 2nd bank is running peak and hold injector or something.</p><p></p><p>There is a few 3 rotor 20B running with 3 ecu to make things easier then trim the settings accordingly.</p></blockquote><p></p>
[QUOTE="wllim5, post: 507380, member: 206"] Question 2: It uses 2 ECU mainly because is want to run 2 bank of 4 injectors which totally of 8 injectors. 2 injector/ cylinder. Running 2 ECU can run both injector in different map. Maybe 2nd bank is running peak and hold injector or something. There is a few 3 rotor 20B running with 3 ecu to make things easier then trim the settings accordingly. [/QUOTE]
R35 Used Titanium Exhaust
Starting Problem
Did not start the car many months
. So instal new battery but still cannot start. Upon changing fuel pump, able to start . Its AVS fuel pump. The next morning need to crank numerous times then only can start. Then...
S15 driver side front mudguard
Do u guys have any idea where can i get the driver side front mudguard (banana piece)? The mud guard inside the front fender.
Your advice is much appreciated. Thank you.
Questionnaire
1st of all i apologize, cuz i dont really know where to post this..
I juz need
FIVE
minutes of yr time dear zthians.. I have an assignment about this topic n i really need yr helps.. Its about...
vr2turbo
Car Brands
Car Manufacturers
Toyota
Upgrading 20v
