ZTHs....
Wanna up your rev?
Mitsubishi / Proton
Use to drive a Satria 1.6... ecu 5806
Even without modification the engine can actually rev higher and improve 0-100km/h, however the rev cut cut in at 6750rpm. How frustrating correct?!!
Anyway I've the learned how to overcome this and with a little fee (rm150~450), can provide you with this service....4g15 ecu 5507 , 4g91 dohc- ecu 5660 , 4g92 sohc ecu 5806 , 7472, 4g92 mivec ecu 4828 , 7305 , 4g93 sohc ecu 7781 , 4g93 dohc ecu 0450 , 5537 , 4g93t ecu 7377 , 5663 & not forgetting those using perdana wiring and ecu 6267.
e.g for 4g9x which rev cuts at 6750 can up it to 7100 / 7500 / 7750 / 8500 / 10000
For evo 1 / 2 / 3, kena sabar... still learning ecu 7701 , 2468
For vr4 - too old but have an ecu which has been chipped- ecu 8618
Currently providing service for Melaka, Tangkak & Muar, pls PM if service needed.
Honda
Since now i'm into hondas, have learned also to chipped honda ecus..
Currently have some mugen/jun/feel's chips in hand for Honda Egs..
Mainly Ecu code P30/P08.
AT to MT ecu modification can also be done (trouble code 19)
Pls PM if service is require... Thanks for reading.
Wanna up your rev?
Mitsubishi / Proton
Honda
cross breed of godzilla and jz engine
