Main Forums
General Talk
Understanding IP Addressing
<blockquote data-quote="jswong" data-source="post: 1760249" data-attributes="member: 8004"><p>IPv6 doesn't really run on top of v4.. maybe eventually, legacy IPv4 devices will run on an end-to-end IPv6 network, and in the near term, migration would involve gateway devices to translate between IPv4 and IPv6. It's pretty hard to map IPv6 devices to IPv4, I'd imagine.. it's so limited. Maybe use good ol' NAT for that. But to map IPv4 to IPv6, that would be easier. The first few bytes can probably be taken from the switch address, similar to ATM, while the last 4 bytes are the original IPv4 address, and we can pad the stuff in between with zeroes, probably.</p></blockquote><p></p>
[QUOTE="jswong, post: 1760249, member: 8004"] IPv6 doesn't really run on top of v4.. maybe eventually, legacy IPv4 devices will run on an end-to-end IPv6 network, and in the near term, migration would involve gateway devices to translate between IPv4 and IPv6. It's pretty hard to map IPv6 devices to IPv4, I'd imagine.. it's so limited. Maybe use good ol' NAT for that. But to map IPv4 to IPv6, that would be easier. The first few bytes can probably be taken from the switch address, similar to ATM, while the last 4 bytes are the original IPv4 address, and we can pad the stuff in between with zeroes, probably. [/QUOTE]
DIY - interior paint
Dear all,
just want to share my DIY interior paint work. Below is a link to my blog:
Jeremy Yeo: DIY - interior paint
:rolleyes:
e manage removal
if i want to remove my e manage,do i have to reset the standard ecu?
Question to all Skyline sifus
Saw a couple of r34 GTS for sale by grey importers and would say the price is quite reasonable. Anyway, found out that the 4 door version is cheaper (suit my budget) and need some answers before committing to one...
Main Forums
General Talk
