Main Forums
Car Talk
Unbalanced ride height
<blockquote data-quote="vr2turbo" data-source="post: 1064328571" data-attributes="member: 92229"><p>You should be able to switch the springs only, as for the absorbers cannot because of the brake line attachment.</p><p>Not sure of the mounting points though. If mounting points are okay, then probably cam cable tie the brake lines if you dare....</p></blockquote><p></p>
[QUOTE="vr2turbo, post: 1064328571, member: 92229"] You should be able to switch the springs only, as for the absorbers cannot because of the brake line attachment. Not sure of the mounting points though. If mounting points are okay, then probably cam cable tie the brake lines if you dare.... [/QUOTE]
More coverage of the 2nd Attack! - by Autogridz.com
http://www.timetoattack.net/wp-content/uploads/2010/07/DSC2375-600x398.jpg
Time to Attack: Sepang Round 2 kicked off last Sunday in Sepang International Circuit and the time to beat was 2:30.421 that was set in...
Driver side door cannot open...
Hi guys....
Now my FD driver side door cannot be open from inside or outside... Any idea and solution? Now Im worry how the door going to be open before it can be fix...
DIY : Change Power Window Switch
To change a new Power Window Switch.. on a Civic EG (Most cars are the same)
http://www.tbspeeders.com/forum/files/dsc03973.jpg
Take off the screw to the handle...
Main Forums
Car Talk
